Using a Remoska on the gas hob (1 Viewer)
Jane And Rog
1,178
6,739
Ashford, Kent
Adria Twin 640 SGX
Since 2017
Hi,
Our van doesn’t have an oven. Currently we use an Omnia oven occasionally - oven chips are brilliant, warm through rolls, that sort of thing. But the Omnia is an odd shape (torus) so not great for heating pies or shop-bought lasagnes, for example. And it takes up extra storage in the van.
I started thinking of replacing the Omnia and our largest pan with a Dutch oven type pan - maybe cast aluminium, with a similar lid, so that it would work both as a small oven and just as a normal pan. Lakeland sell these for example:
Any thoughts on that?
Then I wondered if a Remoska could be used on the hob, as an ordinary pan. I think my researches seem to be saying that that’s only possible with the Tria, which is heavier. And then, to use it off-grid as a Dutch oven on the hob, I suppose I’d need to find a decent solid aluminium lid to retain heat. Has anyone done this? Would any lid of the correct diameter work?
11,955
9,166
Hi Ramoska work off electric which is in the lid of the pan. Years ago I had a really thick Ali pan ( like a big frying pan with a lid) I think it was called a club pan, this was filled with all your meats/ pies & veg etc sort one pan cooks all. I remember you put it on the lowest heat possible or it was easy to burn thing's but once you got it right it cooked everything beautiful 👍
138go
3,276
14,613
Carthago 138
Since 2001
We don’t have an oven. I use an electric Remoska, which will run off the inverter when we don’t have EHU. I love the Remoska and highly recommend one.
Zoobec
671
2,458
Peugeot Boxer PVC
What about a double skillet?
Aug 19, 2013
2,999
4,332
Wells, Somerset
Elddis 115
since 2004
Our double skillet is very good, however we also do have an oven, which is better than the DS for oven chips, but I guess we could do without the oven. It never occurred to me.
Oct 29, 2016
4,530
53,588
Surrey
Carthago C Tourer
We use the Remoska a lot at home & in the van, but I wouldn't put pan on gas hob direct, as although its non stick its not that heavy duty enough.
I use Tefal Deep sauté pans, with glass lids, 2 in the kitchen at home, 1 in the van, and use them for everything, inc hob to even, as they have silicon handles.
The best part of using in the van is that you can do a fry up, or sear off meat/fish, put the glass lid on and you dont mess the hob up with fat splashes, and you can see it cook.
They also last for years, good quality non stick coating, I also polish up the circular Ali bottom with a wire wool soap pad to keep them looking good.
I had a Meyer one for years, but The Tefal is just as good.(y)
LES
Feb 19, 2018
5,063
86,405
EAST ANGLIA
Murvi Morello
Since 1975
For versatility, I would love to take my big Wok but it's too big and the rest just seem too small but, if it helps, there are some thick based Woks about, maybe that is what you are looking for? :unsure:
denisejoe
5,656
12,207
Warden isle of sheppy
A ramoska is a fairly heavy pan that you could put on a gas hob but you have to mind the wire on the lid
Joe put this but I wouldn't use it on the hob I don't think it's heavy enough! The weight seems to be in the lid.
I use a Tefal sauté pan with glass lid when we go away for any length of time but don't bother just for weekends as I tend to take stuff that just needs reheating or can be done on the BBQ.
two
Aug 4, 2011
4,911
4,582
West Midlands
A-Class Fiat
Those Lakeland pans are good but I think they are designed to be used in ovens, as much as on a hob. They'd hold a lot more than an Omnia as well. An advantage of the Omnia is that it's very light. Maybe adjust your diet when on holiday?
Armytwowheels
6,481
14,902
Market Harborough
Carthago S Plus - Iveco
Since 2011
I have used my remoska pan on the gas hob to start a meal off. Then putting the lid on to finish cooking. It is ideal to start off a chilli and then continue with the electric lid, which concentrates the flavour.
Jun 29, 2012
194
364
Penrith
DIMS van conversion
since 2010
From memory, there is a warning on the "ordinary" Remoska instructions that you shouldn't use the pan directly onto a heat source - as the metal is not thick enough (and may warp?)
This is a bit inconvenient as we like to make meals which start by frying/browning the ingredients and so we have to use another pan before transferring to the "ordinary" Remoska.
Which is why we bought their newer "Tria" : - https://www.remoska.eu/en/remoska-tria
The pan is considerably heavier/thicker and the Tria has all the advantages of the normal one PLUS it's a low-pressure cooker and has a second lid so that you can use it as a conventional pan.
We really like Remoska - but perhaps they are like Marmite.
As well as the fact they they only use 2-3 amps they're lighter than a typical caravan/campervan oven
Jan 3, 2008
3,345
5,364
Pakefield, Lowestoft, Suffolk, UK
Looking
Hi,
You would be quite likely to melt the handles on the Remoska because the heat from the gas flame will be running up the sides and in any case the metal is quite thin and I doubt the non stick would stand the direct heat from underneath. A decent heavy cast iron casserole With a lid is probably your best option.
Jan 22, 2017
565
15,236
North wales
Ace Napoli (Swift)
Since February 2019
My vote is also for double skillet ..so versatile!
43,423
50,192
Ramoska pan CANNOT be used on an open flame .
The metal is too thin and the none stick coating will flake.
No 5 in the list....
bobandjanie
8,175
15,851
Javea, Spain
Pilote V600g
The double skillet comes with a glass lid and 2 deep pans.
We found our glass lid very heavy, and swapped it for a lightweight one off our big curry saucepan indoors, but yes like our double skillet. 😁
Along with our monkey, two saucepans, pancake pan, remoska when we have electric, and our oven that is used on the gas hob. 😁😎 Bob.
Aug 19, 2013
2,999
4,332
Wells, Somerset
Elddis 115
since 2004
... And you too have a pvc? Where ever do you store it?. Mrs Dorwyn, who's in charge of storage would not allow all that stuff. That's why we got rid of the Remoska, which you can only really use on hook up, which we rarely have.
Jane And Rog
Jane And Rog
1,178
6,739
Ashford, Kent
Adria Twin 640 SGX
Since 2017
I think the whole point of the Tria is that it is heavier, and with those extra lids, can be used on the hob. Those lids also mean that the electric lid is nowhere near the gas, just stored away for if you’re on hook up. Does anyone have the Tria?
Jane And Rog
Jane And Rog
1,178
6,739
Ashford, Kent
Adria Twin 640 SGX
Since 2017
Two, I do adjust my diet on holiday! I’d never eat a pie or a ready meal at home, it’s all salads, fish, game, and lots of veg. This weekend in the van I cooked a rabbit stew with smoked bacon cauliflower purée and leeks. In the summer we cook on the bbq. But sometimes it’s wet, and sometimes HWMBO wants a pie, and sometimes I want a rest from cooking, and we’re not near a good restaurant, so I fancy having a lazier option.
Jane And Rog
Jane And Rog
1,178
6,739
Ashford, Kent
Adria Twin 640 SGX
Since 2017
Ours is an Adria Twin SGX with the lifting bed - loads of storage underneath it. But the point would be to replace the pan in the middle drawer (and the normal lid) and keep the electric lid in the back for occasional use on hookup.
Jane And Rog
Jane And Rog
1,178
6,739
Ashford, Kent
Adria Twin 640 SGX
Since 2017
Thanks! Could you buy another solid lid for the Tria, so that it retained enough heat to use like the Omnia oven?
Jun 29, 2012
194
364
Penrith
DIMS van conversion
since 2010
The Tria comes with 3 lids.
1. With the heating element inside
2. The (low) pressure cooker and the
3rd which is for use as a conventional pan
Jane And Rog
Jane And Rog
1,178
6,739
Ashford, Kent
Adria Twin 640 SGX
Since 2017
I know, but 2 and 3 are glass lids. I was asking if the pan would take a non-Remoska solid aluminium lid. Is it a standard circle, and what’s the diameter?
Jul 2, 2019
1,217
4,440
doncaster
just looking
since 2010
I wouldnt put my remoska on the gas top
i have a dutch oven of the old style for stove cooking.
its very heavy, i bought it from an antique shop, but if you look on ebay and just type in ,club dutch oven you will see the sort i mean ,you can bake a cake in them ,years ago they used to have house parties ,where you could buy them,rather like tupperware ( showing my age) lol
