Urgent need help on electric hook up (1 Viewer)
Sep 21, 2016
3,849
14,644
DERBYSHIRE
Frankia i740
since 2007
Hi Mr Gina M here we are on a camp site on hook up and the electric has gone. I have looked in the locker and the extension reel has a red light on. Mrs Gina M is panicking as she has a lot of food in the fridge and ice cream in the freezer
Aug 2, 2022
354
1,743
Sun Living S70 SC
The red light on my extension reel it signifies power.
On others it could be an indication that the cut off switch has activated.
Is there a reset button?
It sounds as if electricity is coming from the camp supply to your motorhome.
Has the RCD board tripped out?
Mar 14, 2020
697
563
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
Circuit breaker on post?
Circuit breaker in van?
Red light must mean power getting to cable?
Any pics available to post?
Chipster
1,011
1,126
East Midlands
Getting there!
You have a Frankia right? Assuming you have power at the site Ballard. are you still using the original retractable cable reel? These are notorious for being fickle. Second you could have a faulty trip in the van consumer unit. I’ve had both issues.
Gina M
Sep 21, 2016
3,849
14,644
DERBYSHIRE
Frankia i740
since 2007
This is the photo of the lead in the locker.
Stupidly we have not got the manual with us.
It's a frankia
Gina M
Sep 21, 2016
3,849
14,644
DERBYSHIRE
Frankia i740
since 2007
When I disconnect from the bollard light goes off on the lead
Feb 27, 2011
14,933
77,683
UK
Self Build
It's a frankia
It looks like power is getting into van judging by the red light?
One of two things I would guess.
1) Cable reel overheated. Does it feel warm to the touch? If so disconnect power and let it cool down. Unroll as much cable as you can.
2) otherwise check the trips in the consumer unit inside the van.
Does any 240v stuff work in the van? or is everything dead? Sockets, heating, fridge etc?
Feb 27, 2011
14,933
77,683
UK
Self Build
Can you take a picture of the consumer unit in the van please?
TR5
Apr 30, 2008
168
224
West Berkshire
If you are on a site, and you are not too confident or competent with mains electrics, I'm sure there will be someone on site that could help. Is there a duty warden, for instance, or a friendly neighbour, that could assist?
Jul 6, 2009
1,853
2,312
Sometimes the trip in your vans consumer unit will trip but the lever stays up, it does sometimes on our Burstner. Just try switching the rcd and mcb’s off and on a couple of times. If you have power to you consumer unit it should trip when you press the test button (if you have one not all do) good luck
Gina M
Sep 21, 2016
3,849
14,644
DERBYSHIRE
Frankia i740
since 2007
Great spot 👏 👏 👏
Mr Gina M , is all the cable off the reel? That may add to heat build up.
Ok I disconnected from the post unrolled the lead and unscrewed the inner ring of the lead holder and exposed the switch connected the lead to the post pressed the lead button light went out now all working. Thank you everyone for the advice. Mrs Gina M has just rewarded me with a beer.
Feb 27, 2011
14,933
77,683
UK
Self Build
I think you probably want to get rid of that reel thing and just use a normal hookup lead? But I suspect you already know that :)
Glad to see you are sorted. (y) Enjoy your beers :)
Oct 29, 2008
5,118
6,117
West Yorkshire
PVC
since 2008
The frankia reel will trip if its left partially wound up to avoid a fire so should always be fully unwound. A lot of people dont like them as you need to spool all the cable off to run any decent ampage over lighting.
I did like ours and if you are removing it I will happily buy it from you.
May 4, 2023
255
207
Just looking
ALWAYS, ALWAYS NO MATTER WHAT LEAD YOU USE UNROLL IT ALL!.... EVERY TIME! (Yes I am SHOUTING!!) 🗣️
Gina M
Sep 21, 2016
3,849
14,644
DERBYSHIRE
Frankia i740
since 2007
Hi everyone so this morning on site I was chatting to my neighbour and I asked him if he had any issues with his electrics as ours went in the end.
As it happens he was a retired electrical engineer and had a look at the extension reel and the red button. He established that there was an issue with the switch and disconnected it and now everything is working. So I assume I just order a new switch or do I just leave it?
TheBig1
17,672
43,584
Take the reel out and fit a standard socket. Those reels are notorious for failing. Rolled up wires quickly overheat. If fitted the trip will protect you in time. By bypassing it, you have deleted a safety feature. Next time it could catch fire before you realise.
Am I being overdramatic? Nope, as a retired electrical engineer I have seen the results of coiled cables passing current till they burn
