Unknown instrument panel warning light (1 Viewer)
Oldgustaf
212
141
Far west Wales
Dethleffs T6501B
Since 2019
Anyone know what this light means (red water tank with fan). It's on the instrument panel but I cannot find it in the Ducato handbook, so wondering whether it's a Dethleffs addition maybe?
BishBosh
138
268
None
Upgrades!!! of course
Maybe fuel filter warning light? Or water in the fuel warning?
Also not much help but looks like it’s been discussed before....
Oldgustaf
Oldgustaf
212
141
Far west Wales
Dethleffs T6501B
Since 2019
It's a low coolant level warning light. Have just been out to check coolant level - and as I thought, it's spot on where it should be. I'm now wondering whether the buzzing sound from the dashboard, the dim red coolant warning light - and the occasional starting problem (turn ignition but just clicks rather than turns the starter motor) are all related to the 'earth connection failure' mentioned above.
Oldgustaf
Oldgustaf
212
141
Far west Wales
Dethleffs T6501B
Since 2019
Thanks for this. I've discovered that coolant fluid level warning. Mine is glowing a dull red, not bright red - and the coolant level is exactly as it should be.
Lenny HB
53,961
152,015
On the coast in West Sussex
Hymer B678 DL
Thanks for this. I've discovered that coolant fluid level warning. Mine is glowing a dull red, not bright red - and the coolant level is exactly as it should be.View attachment 337147
If it's glowing dim it's an instrument panel fault, that will be the start you will find other lights start to glow Fiat will replace the panel for £800 or Cartroix will repair it with a lifetime guarantee for £150.
Lenny HB
53,961
152,015
Hymer B678 DL
