Tyres and Load rating etc. (1 Viewer)
jeffcav
26
33
Cheshire
Hobby 700
Hi Ladies and Gents,
I have a couple of tyres that are badly cracked, whilst looking for prices i came acroos the term load rating, does anyone know what that should be for a Hobby700/750? I would ask what make/ model you prefer, but that is a can of worms for another time.
Secondly, do you always change in pairs, say LH3 and RH3 or staggered/as required or in no particular order?
And finally, do you bother with yearly habitation checks on an older(18yr) van?
I know all the problems and dont need somebody else reminding me ;-)
Cheers in advance
Mar 16, 2016
1,072
6,601
Norfolk
Hymer S520
Pete
SandraL
1,373
985
Somerset
Hymer b694sl
There will be a plate on the van from fiat, another from alko, and lastly from hobby.
The plate will have axle weights, max weight and train weight.
The newest plate is the important one, in your case hobby.
Look at the axle loadings, you need a tyre with a load rating equal to the highest axle rating.
Note axle load needs to be divided by 2 to get tyre load rating.
I have assumed its a fiat with an alko chassis.....
denisejoe
5,627
12,085
Warden isle of sheppy
Since 2004
Would be a tag axel
J
jeffcav
26
33
Cheshire
Hobby 700
for tyres find your axle weights and and see what rating you need here https://www.gov.uk/guidance/mot-ins...al-vehicles/appendix-b-tyre-load-index-tables
So from this guide if i get 111 rated tyres, that is 2180kg/axle, with three axles is 6540kg. well over what i need as its 6.4tons, and my max weight is 4.5tons, unless i am missing something.
thanks everyone.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
thanks everyone.
Check individual axle loads, as some axles may take much less than others. As you typically want to swap wheels around, use the axle with the highest load to determine the tyres. The axle loads should add up to more than the MAM. Otherwise, it would be very inflexible. It is the highest max axle load that determines the tyre load required. You can't take the total MAM and divide by the number of tyres. Also, if you have DRW rather than tag axle, the tyres are downrated. This is what it meant when you see a tyre have two load ratings. The highest is for a 2 wheel axle and the lower for a 4 wheel DRW axle.
J
jeffcav
26
33
Cheshire
Hobby 700
I found my axle max loads -
AXLE 0NE 1850KG
AXLE TWO 1500KG
AXLE THREE 1500KG
so i am good to go on all of these tyres, and you were correct on the front axle requiring a different rating. cheers
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
AXLE 0NE 1850KG
AXLE TWO 1500KG
AXLE THREE 1500KG
Technically, anything 105 or over is fine (although a manufacturer's recommendation for a higher load rating must be followed). Typically, two load ratings are available for any particular tyre size. I don't know what tyre size you have.
RowleyBirkinQC
2,349
227,904
Dazed & Confused
From a load capacity perspective we are over spec‘d then, 3.5T van which came with the optional 16 inch alloys and 116 load rated Michelin Agilis Camper tyres on both axles. Guess it could have been dictated by the available tyre options for wheel size (not had cause to verify as yet)?
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Many 3.5t vans are actually 4.0-4.5t vans that have been downplated. However, their wheels and tyres would have been specced for the higher MAM.
