Tyre pressure quandary? (4 Viewers)
Blue di + jean
47
5
Burstner T686 delfin
Since 2000
We have burstner t686 3.o ltre on a renault master chassis. According to the burstner manual it states: use 225/65 R 16 C (112/110) Q tyres and tyre pressures are front: 4.5 BAR (65 PSI) - rear: 5.5 bar (79 PSI) .We had to go to NTS to get our tyres checked and was informed that our tyres had it stated on their sidewalls the safety pressure was not too exceed 69 psi ??? Does anyone have a clue -if Burstner are stating what tyre and giving a running pressure of 79 psi and the tyre they state has on sidewall not too exceed safety pressure of 69 psi ? What should I run at? .normally I would run at 79 psi as manual states but from insurance view if I have an accident ( running at 20 psi over the back I wonder where I would stand?. Any info gratefully appreciated george
18,049
48,222
Go by what's written on the tyre wall. I'm assuming you don't have tyres fitted which match the specification described in the handbook. If you do, then the handbook would be a good guide but only of course if the recommended pressure isn't higher than whatever is written on the tyre.
There are numerous threads on here about tyre pressures. Ideally, you need to go to a weighbridge and find the weight on each axle and then check what the pressure should be using something like this: https://www.tyresafe.org/check-your-pressures/motorhomes/
Blue di + jean
Blue di + jean
47
5
Since 2000
They were replaced for us buying van 4 new tyres fitted. I have checked sizes and they're exactly what is stated in Burstner manual?
Camdoon
1,531
2,808
Adria Matrix Supreme
I quote from Continental having written to them about my tyre pressures "The 69 psi written on the side of the tyre is for the Northern American market only and the inflation pressure of the tyre can exceed this value within its safety operating range." Mine are "ContiVanco Camper 225/65 R16 (CP*) 112 R tyres"
My figures are 47.1 and 76.1 but recommendations go up to 79.8 psi
Blue di + jean
Blue di + jean
47
5
Since 2000
Just checked make and they are " effitrac three a" and compete size is 225/65 R16 C (112/110) Q don't have a clue as to make never heard of it before? But taking on board your part about 65 psi for no there territories thanks george
androidGB
363
490
Bristol
Since 2001
THe only thing I can add is that camper tyres are designed to be fully loaded all of the time, unlike commercial van tyres, and Michelin
state their camper tyres run at 80psi irrespective of axle loading
Andrew
Jan 8, 2013
8,494
11,535
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
My original Burstner Continental camper tyres had a section on the side walls saying something like 'Motorhome vehicles can increase their pressure to 5.5 bar' Unfortunately I have just changed them for a new set of Michelin camper tyres but I'm pretty sure they have set the pressures as per the Burstner/Fiat label on the passenger door pillar which are pretty high.
Sep 28, 2015
2,034
2,634
Hymer B544
2001 Caravans 2011 Motorhomes
Take no notice of any of that twoddle. Get weighed, know your front and rear weights and follow Continentals Technical Data Handbook.
2657
I tend to think that tyre manufacturers know more about tyres than van manufacturers and converters, I follow what the tyre manufacturer recommends on the sidewall for the maximum load.
Just a question, why would a tyre produced to EU specification have recommended pressures only applicable to the USA?
Jun 17, 2012
2,939
9,995
North Essex
Autotrail Delaware
>12 but <13
The pressure question was raised last year. I posted this picture. Hope it helps.
Dec 12, 2010
5,440
21,718
Cumbria
I run the rear tyres on my T680 at 65 psi, running at a higher pressure makes for a harsher ride. I run on Toyo H09 winter tyres all year round.
Blue di + jean
Blue di + jean
47
5
Since 2000
I'm beginning to understand the word ""Minefield"" I think I'll bite the said bullet and go for two new rear tyres that state on the sidewall '5.5 bar' thanks one and all for all inputs. And we thought it was less stress campervaning than owning a house . DUHHHH! cheers all george
joka250
907
1,554
Fylde Coast.
Since 1985
Tyre manufacturers do, as you rightly say, know more about tyres than vehicle manufacturers but I suspect many tyre fitters know less than they should.
Reason for USA pressures is tyre manufacturing is a global business and like most regulated products they try to cover all avenues, "it keeps the costs down!!!!?".
Sep 28, 2015
2,034
2,634
Hymer B544
Try reading this from the tyre manufacturer Continental. This is why I prefer Continental tyres as you get the information you need.
I recently considered Michelin but on enquiry about correct tyre pressure, they always say 65psi front 80psi rear, regardless of the size or weight of your vehicle or tyres, which is ridiculous.
Think I'll be choosing Vancontact 4season next.
http://blobs.continental-tires.com/...998ef8b3/download-technical-databook-data.pdf
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
If you intend to run the tyres above 65 psi / 4.5 bar then make sure they are fitted with appropriate high pressure metal stemmed valves. The standard rubber stemmed Schrader - type valve is rated for pressures up to 65 psi only.
Emmit
8,057
17,809
Pilote Explorateur
Jan.2014
I might be wrong on this but every car I've ever had gives different tyre pressures dependent upon the load ie 2 pax 36psi 5pax 42psi.
Why should it be any different for motorhomes? Not all motorhomes are over laden??? but it's as if Michelin think we're all at the limit of our load.
Reactions: Ode
