Tve Aerial as well as Dish? (2 Viewers)
Clewsy
118
178
Norwich
Frankia 7900 Platin
since June 2014
We are getting our new MH mid June (excitement building daily) - we have already specified an Oyster 85 Sat system and the dealer is suggesting that we should also fit an aerial for normal digital signals (Status 330 being proposed).
Is this a sensible suggestion from the dealer or just an attempt to make more money?
:thanks2:
SMB
Apr 26, 2013
1,230
1,347
Spain
Coachbuild
Fulltiming since February 2013
I have an oyster 85cm dish fitted and receive a brilliant picture from it as far away as Southern France. I don't understand why you would need an additional aerial fitted to be honest, although I don't know much about them. A more experienced Funster may be able to assist but I can't see the benefit :Smile:
ps enjoy yr first trip!
Clewsy
Clewsy
118
178
Norwich
Frankia 7900 Platin
since June 2014
Thanks - the dealer is saying its for when we can't get a TV picture by satellite due to trees /buildings etc. but I'm not convinced that will often be an issue.
If it is we will have to open another bottle & entertain ourselves.:Blush:
SMB
Apr 26, 2013
1,230
1,347
Spain
Coachbuild
Well I must admit that when I arrive at a new campsite I always try and find a pitch that has very few trees but that is because i have internet connectivity through my dish. I'm not that bothered about the TV to be honest but I know what the dealer is saying. I suppose it depends if you are going to be in the UK mainly or abroad, and also if you are going to be using campsites or wildcamping, where you can choose your spot! The trees do affect your signal, but I would hope that a more experienced Funster will be able to advise as I have not had a normal aerial fitted to the van therefore have no experience of reception etc.
SMB
Apr 26, 2013
1,230
1,347
Spain
Coachbuild
But the wine solution seems to be the best idea! :thumb:
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
I have an Oyster 85 dish and a Necvox digital aerial. I chose to fit the digital aerial too so have the choice and also in severe weather it's always good to put the dish down.
The Necvox is a fantastic aerial and only small. If you search on eBay you will see them. It even works inside the MH but when I fitted my solar panels I also roof mounted the aerial. The base is magnetic but with the MH roof been aluminium I cut a jar lid the same diameter, sprayed in with Zinc paint and sikaflexed it to roof, so the aerial now sticks to that and I routed the cable through the same roof gland as my solar cables.
I can post pics if needed.
Mikey RV
4,902
24,248
Devon
Burstner Elegance I821G
Since 1977
We have a satilite dish but are also going to get a digital aerial fitted because if it's too windy we put the dish down anyway just incase of damage., or we may just change to a dome which we had before. :thumb:
Chris69
52
40
Derbyshire
Coach built
since 2006
Have you considered a sat dome instead of dish?
No problems with windy condition with dome.
I would also consider an aerial and an external aerial inlet.
If you use caravan club sites there is often a booster system on site which you can plug into.
I have a dome and also carry a very compact Avtex aerial which can be used inside or out. It can be fixed with suckers and removed when no required.
I don't have a fixed aerial.
Chris
scotjimland
2,335
10,105
A Woosh bang
I had both .. belt and braces.
I used the Sat dish when abroad or in the UK when you have poor or no terrestrial signal.
Aerial for the UK for use in stormy/windy weather.. or when trees block the sat signal..
Aerial is no use abroad unless you want to watch foreign stations.
If it's stormy abroad you read a book or listen to music
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
hi what the dealers telling you makes sense but the 330 is next to useless and at aprox £80 to buy (not fitted) its also a waste of money --I have recently bought one of these Broken Link Removed
and they are very impressive :thumb:-less than 40 quid easy to wire the 12v supply or plug into cig thing and a long co ax means you can mount it anywhere on the van or simply throw it in a cupboard ::bigsmile:
terry
Scout
3,959
121,326
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
Line of site may well be an issue, it has at time been so for us, and we use a portable vucube (dome) we can place on the roof or around our pitch on a extension lead. whether or not this would be an issue for you on the odd occassion this happens is up to you.
I have both, but cant remember when I last used the arial.
best idea, your not glued to the tv
Soozywoozy
534
452
Oxfordshire - edge of the cotswolds
Hymer B 704SL
2014, 2 motorhomes
We have both, but bought our digital aerial from maplin - about £40 which sticks on inside or outside.
(Check your tv can take a 12 volt powered external aerial - ours is avtex)
Obviously only good for uk when as others have said trees obstruct / high winds a problem. Used it twice so far (bath and somewhere in North Norfolk)
In Europe no use at all, but again still the tree problem.
Note to all - campsite memling, bruges, Belgium - no satellite reception at all, (last week) not a single van had their dish up, too many trees, so don't just think far south as an issue.
We are not tv addicts but I do like the bbc news!
We also have all our dvd's backed up on a portable hard drive which plugs into the TV. For instant library should it be chucking it down
Chris
21,054
278,776
None
10 years
We have both, set up to different TV's.
Don't know why because we don't watch much tv:Doh:
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
I used a potable sat dish a few times, also a put up a on the ladder aerial---
We found we wanted to get away from all the soap c**p when off, the rest is just news and tripe which i can pick up on my phone if needed, so we don`t bother with it, we just go to a pub somewhere.
Unless WW3 has broken out even the news is boring--i sooner log on to Shifty`s latest offerings :thumb: not so pc.
Bailey58
8,817
29,578
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
I want one, how many bottles does that take? :ROFLMAO:
Sorry!
Back to the OP, I wouldn't bother with an aerial now but I would have had the dealer fit one before we collected the van if I'd thought about it. As said, very windy conditions would mean the sat dish going down, we don't always remember tree problems before we park up and often on a club site there's not too much choice of pitch. The dome may be more versatile weather wise but the 40cm Roadpro that we have does add height to the roof.
CandC
196
335
Cornwall
Old School :D
Used to go with the olds! Now I have one of my own :)
I can't give any recommendation for particular sat systems or aerials, but the other day, I saw a hired motorhome cruising down the A38 at about 65 with a sat dish spinning round and round on the roof. I remember thinking that that probably wasn't such a good idea :ROFLMAO:
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
I used to have a £10.00 Aerial clamped to a brush handle and clamped to my bike rack never let me down in the UK, 85 Dish down in Spain no good, I have a 1.2 free standing Dish it wont work now it seems you need a 1.3 or above, it went off in Portugal also. Pete :Sad::Sad:
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
:thanks2:
Ours came with satellite and terrestrial. We use the terrestrial far more. It works when driving (for the kids, not the driver!). It doesn't require 10 minutes up a ladder adjusting. It doesn't blow over in high winds. I'm sure a dome is better than our rubbish dish, though. We only use the satellite when the terrestrial has no signal.
Kelso
113
179
Whitchurch, Hants
McLouis
10 years
Sat vs Ariel
Hi,
We have a motorhome fitted with a dome satelite system, but have found dead spots around the UK, so have had a terrestial ariel fitted as well.
I would say i is definitely worth having both.
Also you can fit a freeview box (£50) eBay, which will allow you to record 2 programs as well.
Hope this helps.
Margit & Kelso
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Aerial is useful at sea :thumb:
:ROFLMAO:
