Tv size in new swift Kontiki 794 (1 Viewer)
graham_the_baker
swift Kontiki 794
Hi we have just bought a new 794 and i was wondering if any knows the maximum tv size we can use in lounge and bedroom?
thanks, Graham
Mar 31, 2022
71
60
Milton Keynes, UK
Kon Tiki 784
Been caravanning for years but now ordered my first motorhome
the t v brackets can take up to 7.5 kg I am fitting the same ones that the supplier use in my 784 i will have a 19 inch in the bedroom and a 21 inch in the lounge area if that's an help but I have seen larger ones installed in a 794
e
Jan 2, 2021
82
100
Castle Donington
Swift Kontiki 874
Newbie
I installed a Samsung 24" 12-volt smart monitor just inside the door which works great with the 5G wifi and a Samsung sound bar. I'd like (and there is room for) a 28" version, but I've not found a 12-volt option yet.
Mar 25, 2023
Autotrail imala
e
Which brackets did you use and what fixings? Especially as bedroom position backing on to bathroom wall.
Tia simon
Jan 3, 2015
221
324
British West Hartlepool
Swift Kontiki 884
Since 2017
we have a Cello 22" I put some MDF in the cupboard behind when I drilled the holes
Sep 3, 2012
7,571
26,108
Cheshire
C Class Elddis 175
8+ years
If you check the specs of some of the modern tvs they are potentially 12v the plug is usually a transformer from 240 v .the wattage is very low on modern tvs that they don't need high amps/ volts. (y)
May 22, 2015
1,427
2,599
Wem Shropshire
Carthago E Line 51QB
Been getting away since 2008
Avtex do a 27” smart tv.
