- Sep 17, 2022
- 7
- 15
- fiat ducato swift
Had ask for help with no light on controls/ no heating.no reply.
So having fixed the fault I thought I would pass on some knowledge.found the main PC board burnt.after searching inter. Etc. I found a basic diagram.checked connections and continuity to the next component in line the circulation motor.as I was unable to test this ( as it is a motor with its own PC board) I found a great company in staffs A&R electronic developments ltd. Who repaired the component Fantastic place to deal with .fixed working fine now ( the reason I thought the component was the main fault was will doing tests with the motor disconnected the control lights came on and the boiler fired up. I hope this small info helps someone
Ian
Ian
