Personally I don't think it's a voltage thing.
Possibly a damp issue due to condensation.
I am having similar problems. First was a faulty battery causing low voltage and B0100-49 fault.
Crashdata repaired the ecu. I fitted a new battery, charged it over several days and then fitted the ecu. All good for a few days until I started the van on a cold morning. B0100-49 fault again.
This time, Crashdata say the fault is permanent and a new ecu is required (reconditioned - i.e. old unit reprogrammed to my van!) @ about £360. They believe that the hard start-up was the cause. If so that is a piss poor design from Fiat.
The lady also told me that over the past year, crashdata repairs to airbag ecu's are to a majority of campervans/motorhomes that are just sitting around. She also said that they rarely get any commercial van failures as they are in constant use.
To me that would imply faulty trickle charging of the started battery.
Sure enough, the Shauldt was only charging at 12.8v !
More expence.....
These are very easy to fit and log voltages with cranking test too.. £25
<Broken link removed>
It's possible, I think nobody at FIAT really considered in the design of the cab that it would often be swimming with condensation from bodies spending the night in there.....Personally I don't think it's a voltage thing.
Maybe they didn't think about motorhome use but you'd be surprised at what the electronics manufacturers put their circuit boards through during testing, I can only speak for Pektron in Derby but it's typically 80°c for 30 min then -80°c for 30 min continuous all logged for a period of 3 months and the board has to work flawlessly. Then there's a vibration table that looks quite horrendous but I never saw that working, a dust chamber that uses Japanese volcanic dust and a radio interference chamber test. Forgot the name for that, Lenny or autorouter will know.It's possible, I think nobody at FIAT really considered in the design of the cab that it would often be swimming with condensation from bodies spending the night in there.....
had the same fault on my peugeot was not a member here then did not know anything peugeot charged £560 and wanted to keep the unit. I retrived the unit looked on the internet identical one from bosch £75. The mechanic did say that they had fitted an extra earth wire as recommended by the big 3 engine groups should have joined this site years agoThey could be susceptible to transient high voltage pulses just after the starter motor stops, the processor throws up a fault code but doesn't record the peak voltage... Just a guess, poor design whatever it is.
That's very interesting thank you, I did visit Lucas years ago & remember seeing them test banks of dashboards to the 9 (?) hour concept, that bad electronics often fail in that timescale?Maybe they didn't think about motorhome use but you'd be surprised at what the electronics manufacturers put their circuit boards through during testing, I can only speak for Pektron in Derby but it's typically 80°c for 30 min then -80°c for 30 min continuous all logged for a period of 3 months and the board has to work flawlessly. Then there's a vibration table that looks quite horrendous but I never saw that working, a dust chamber that uses Japanese volcanic dust and a radio interference chamber test. Forgot the name for that, Lenny or autorouter will know.
I used to work on the thermal shock chamber.
Hi Jeremy,With apologies if this is a bit of a thread hijack, but, after five relatively trouble-free years owning our 2012 Peugeot Boxer-based Autoquest 180, we have recently joined this unhappy and apparently growing club of airbag ECU fault victims
A similar story to many others... Airbag failure light came on suddenly when starting the motorhome one day before Christmas and remained on, despite attempting to clear it by driving the vehicle and doing a controlled reboot of the main system (e.g. http://www.petercoopercarrepairs.co.uk/peugeot_bsi_reboot_procedure.htm). I enlisted the help of a mobile sparks whose two professional scanners (one £1000 unit and a Snap On unit costing several grand) each of which revealed the dreaded 'B0100-49 Error inside the control unit' code and no others errors.
Sent the airbag ECU off for repair and have now received it back with "before" and "after" reports, which appear to be printouts from the FIat Multiecuscan software. See attached photos - the report with the yellow-highlighted text is the report before they repaired and re-tested the airbag ECU.
There are a couple of things in these reports which I'm not sure about and which I'd appreciate Funsters' advice on, especially from Riverbankannie, Christy, Nigel Crompton and others who have been down this road:
1. The odometer readings recorded against the errors in the reports appears to be many thousands of miles different to my current odometer reading.
The Airbag failure warning and light appeared for the first time ever the week before Christmas (i.e. December 2021), at which point the odometer would have been reading at least 26,202 miles. (I'd successfully MOT'd the van days previously and this was the recorded mileage.)
However, the reports I've received from the repair company give odometer readings of just under 17,000 miles for B0100-49 and the other errors! Based on mileage recorded in previous MOTs and my subsequent usage, my odometer would have last have been at 17,000 miles back in Spring 2019! Has anyone else spotted a similar discrepancy in reports they have received or is it likely that I've possibly received someone else's reports in error?!
2. The post-repair report still shows six other errors:
Have other Funsters also seen similar errors on their post-repair reports? If so, did the faults disappear when you reinstalled the Airbag ECU or did they have to be cleared using a suitable SRS-capable OBD2 tool?
- U1703-07 Communication with Instrument Cluster (IPC/NQS)
- B0106-1B Driver's pretensioner resistance
- B0107-1B Passenger pretensioner resistance
- B0104-1B Passenger airbag resistance (1st stage)
- B0103-1B Driver airbag resistance (1st stage)
- B0127-13 Driver's seat belt switch
Like some others in these forums, I was really surprised to see the root cause attributed to low voltage with the advice to get my battery checked. I replaced the original vehicle battery in January 2020 and fitted a new leisure battery and MPPT solar controller (with logging) last year. I have a Battery Master and am in the habit of checking the voltage of both batteries at least once a month and regularly downloading the logs from the solar controller, with no issues at all.
One possible cause that did occur to me was that I replaced the casing of my nearside wing mirror immediately before the airbag failure appeared. Perhaps unwisely, I did not disconnect the vehicle battery before unplugging and removing the heated mirror glasses, so I guess some sort of short may have occurred - not that the ignition was on at that point. The auto electrician dismissed this as a possible cause of the airbag fault, but I thought I'd just mention it in passing...
I'm obviously going to follow up the above queries with the repair firm, but would appreciate any advice Funsters can give on the above so that I am armed with as much info as possible.
Sorry for the lengthy post but thanks for reading!
Cheers,
Jez
