- Feb 26, 2013
- 1,653
- 9,617
- Giottiline T60
- Since March 2013
I use the free Ovano VPN, so far no problems with it.
I certainly wouldn't claim to be an expert and the method of using the VPN will vary between devices I believe. On my Android tablet I will install an app called OpenVPN which is the thing the device will connect through, essentially like its own private tunnel, back to the router in my home. Other VPN providers may differ and of course they will connect to their servers not the router at your home. If it works and I log into BBC iPlayer from France, instead of telling me I can't do this because I don't live in the UK it should behave normally because it thinks I am sitting at home in the UK.This is all double Dutch to me, can someone explain how it works to a compleat ignoramus in this stuff, surely you still have to connect to something , never mind where it thinks you are,
So it's not actually quicker, just lets you see things that normally you can't getI certainly wouldn't claim to be an expert and the method of using the VPN will vary between devices I believe. On my Android tablet I will install an app called OpenVPN which is the thing the device will connect through, essentially like its own private tunnel, back to the router in my home. Other VPN providers may differ and of course they will connect to their servers not the router at your home. If it works and I log into BBC iPlayer from France, instead of telling me I can't do this because I don't live in the UK it should behave normally because it thinks I am sitting at home in the UK.
I can't see why it should be quicker, as the local provider just sees it as a call, so to speak. But I did suspect my 3 connection was being throttled in Spain this year. Even with a good 3g connection there were times when it was very slow but when I put my O2 sim card in the mifi things improved significantly.So it's not actually quicker, just lets you see things that normally you can't get
That is what I found, so you will still be on O2 even with the vpn, is that right? Or will it make 3 work betterI can't see why it should be quicker, as the local provider just sees it as a call, so to speak. But I did suspect my 3 connection was being throttled in Spain this year. Even with a good 3g connection there were times when it was very slow but when I put my O2 sim card in the mifi things improved significantly.
I don't know is the short answer. We are off to France at the beginning of September so will be able to check if my DIY VPN works from there, assuming of course I can get it to work in the first place but if it does it should work with any sim card, 3 or O2.That is what I found, so you will still be on O2 even with the vpn, is that right? Or will it make 3 work better
It's not that it's quicker, in fact vpns are usually a little slower. But the french internet provider that three is going through are unable to see the data when I am using a vpn. therefore the throttling doesn't kick in as they can't see what the data is, they just see scrambled data transferring between my computer and the server in the UK which is acting as my vpn.So it's not actually quicker, just lets you see things that normally you can't get
