The installed height of MH Ovens!!! (1 Viewer)
Aug 5, 2018
1,567
3,513
a
Does anyone else scratch their heads at the design installation height of the wall mounted ovens in Motorhomes...
Is there an actual reason they stick them up so high, so much so, short ass member of the family cannot see in the thing!!
I'm actually contemplating the pitfalls of trying to move it down the cupboard space so it's more on top of the wheel arch rather than jammed up near the ceiling..
I guess the vents on the outside of the MH are going to be my downfall though as I don't want to move them. :-(
Badknee
7,421
416,447
notloB
Vantage Neo
Living the dream.
I wouldn't use one I couldn't see into. Imagine trying to lift a casserole out and spilling it over you or a loved one?
How the hell it passed safety standards I don't know, perhaps it didn't?
Feb 24, 2013
13,137
101,668
Bolsover, Derbyshire
Hymer S800
not long enough
our fridge freezer has just failed, being part of a tec tower the whole lot needed to be changed, we have opted for a larger fridge freezer and no oven
Although we will be having some form of oven, as yet undecided other than table top, for occasional use (y)
bigtwin
5,292
10,040
Derby
Concorde
Since 2006
Yes, I’ve always struggled with the height of the installed oven.
Ours is about six inches above the floor level and at 6’3” tall, I have to get down on my knees to see what’s happening in the oven.
We all have our crosses to bear. :whistle:
Ian
Badknee
7,421
416,447
notloB
Vantage Neo
Living the dream.
That's what we did David, oven/grill £25 from Aldi.
Steve and Denise
5,321
14,186
Spalding LINCS
A Class Carthago
Since 2008
Most Tectower ovens are totally useless and fitted far to near to the roof as when you try to use them they heat up anything above them including any wood or plastic trim and head cloth.
We hardly use ours but have made a detatchable heat shield to divert some of the heat.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Can't complain about the height of ours. It's beneath the hob which is OK, but why did Thetford go all trendy and set the dial in a black perspex cover in dark grey lettering, rendering the settings unreadable! :(
Wyn
two
Aug 4, 2011
4,911
4,582
West Midlands
A-Class Fiat
We wondered how we'd get on without an oven when we 'downsized'.
I am pleased to confirm that life is possible and that there are many ways of surviving without one.
DP+JAY
2,538
14,787
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
I fitted two small fans behind the grill above ours.
DBK
18,073
48,358
Plympton, Devon
PVC, Murvi Morocco
This is a good example of why the phrase "it's all about layout" applies in three dimensions. We have a big kitchen and an oven at a conventional height but we know the layout (in 2D) wouldn't suit everyone.
What's the other phrase? "They are all a compromise." :)
HandyAndy
Aug 5, 2018
1,567
3,513
a
Has anyone got any images of removed ovens and what not, so I can get a gander at the way the flue is attached (and whether it can be piped / ducted to the new position without alteration of the outside vent panel)
Lenny HB
54,042
152,471
On the coast in West Sussex
Hymer B678 DL
We have had TecTowers in all 3 vans, yes they are too high, but better than nothing. In the van we have now with a double floor no reason it could not have been fitted 12" lower.
Keep burning food in it lately, since having new door hinges fitted it works like an oven can't get used to it but the grill is still naff.
My mates E line Carthago the oven is another 4" higher than Hymer fit then you need a step ladder for it.
Apr 27, 2008
11,860
14,110
Eastbourne East Sussex
Hymer low profile
Since 1972
Our oven is at a sensible height under the hob and SWMBO uses it all the time. She is 'petite' (French for shortarse) and finds the height ideal. There is a vent behind but we put a vent cover on it in the winter as their is a chilly draught if the wind is in a certain direction.
Feb 24, 2013
13,137
101,668
Hymer S800
not long enough
Ours came out as we knew it wouldn’t be going back in, could be a nightmare to refit
The hole on top is (was) connected to a stainless flexible vent pipe, with jubilee type clip, access is only from outside and helped slightly by a sloping heat panel above the oven
Reconnecting the vent pipe must me a mare of a job with no movement and hardly any room to work
The oven is also very much attached to the fridge, there must be a way to separate them but not easy at first look
Feb 24, 2013
13,137
101,668
Hymer S800
not long enough
Ours is mounted on top of a 9” high drawer to make things worse
Even worse talking to another member theirs is mounted at same height as ours but over a blank panel same height as our drawer o_O
Gazz Kaz+Spag
126
125
Leeds
A Class Carthago
Since 2010
Just had my oven taken out above the tectower this weekend. Hardly ever used the oven. Going to put microwave and possibly a coffee machine in its place.
Aug 6, 2013
11,963
16,582
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Was your oven attached to the top of the freezer & if so how was it held? The reason I ask is that my Tower is coming out for a fridge / freezer repair and it would be good to know in advance how the oven is attached.
denisejoe
5,656
12,212
Warden isle of sheppy
Since 2004
We've got a separate but high oven. I can't reach it as I'm petite too but Joe is over 6 foot and doesn't find it a problem so I just prep the food; he sticks it in the oven, stirs if necessary, gets it out when it's ready. Being a high oven isn't a problem for me, LOL!
Denise
Jan 19, 2014
9,431
24,905
Derbyshire
Elddis Accordo 105
since 2014
I fitted two small fans behind the grill above ours.View attachment 258833
I bought some "Pizza Oven" wadding insulation stuff on ebay, good for up to 1300°c. Put it all round the oven and secured with foil tape. Now the surrounding cupboards are cooler and we use less gas (y):cool:
Jan 13, 2014
3,645
11,828
Leeds - Yorkshire
There is no good reason for Dometic to put an Oven at the height it does on their Tec-Tower other than convenience and style Dark premium gloss finish Fridge,Freezer,Oven all in one Tec-Tower——— wow sounds good too! Only the oven is a waist of space and if you do manage to get any decent heat out of it lucky you, but guess what? Then it melts the hinges of the Oven and they break or jam up. I had eighteen months of torment trying to get mine sorted, it went wrong from new and it was only through the kindness of a Dometic Service Technician that came some 70 miles out of his area on three occasions that I eventually got it sorted.
Of all the Dometic Service Engineers we contacted none would attend a Tec-Tower and I think this just about sums up its practicality, they are a nightmare to work on.
HandyAndy
Aug 5, 2018
1,567
3,513
a
lots of talk about tec towers... which I don't have so kind of irrelevant in this scenario :D
HandyAndy
Aug 5, 2018
1,567
3,513
a
out of interest is your fridge freezer mounted at floor level or is the a panel underneath ?
No they've put a small cupboard below the fridge which is sort of above the wheel arch but above that by a good 8 inches
Dec 10, 2013
3,427
12,500
South Staffs
Pilote P740GJ
Since 2013
I had to fit new new hinges to the oven on our last Motorhome, which in itself isn’t a difficult job.
The trick is to keep the hinges greased with high melting point grease, obviously I didn’t find that out until the old hinges sheared off, I wondered why the door was a bit stiff. :whistle:
Feb 24, 2013
13,137
101,668
Hymer S800
not long enough
that must be just about the only thing not to have broken on our MH o_O(y)
even more typical they will be thrown out still working as attached to the crap fridge freezer :(
