Thanks for all your comments on my interest in a 1994 Talbot express with 91K mileage. But what do you think about MOT results would you be put offf (1 Viewer)
Rlee5
4
Talbot express 1994
Skip to main content
GOV.UK
Check MOT history
This is a new service – Complete a quick survey to help us improve.
L968 PAL
TALBOT EXPRESS​
Check another vehicle
Colour
White
Fuel type
Petrol
Date registered
24 June 1994
MOT valid until
26 October 2024
Get an MOT reminder by email or text.
Download test certificates
If you think the MOT expiry date or any of the vehicle details are wrong: contact DVSA.
Show all sections
MOT history, Check mileage recorded at test, expiry date, and test outcome, Hide​
Date tested
27 October 2023
PASS
Mileage
92,499 miles
Test location
View test location
MOT test number
7404 4368 3272
Expiry date
26 October 2024
Monitor and repair if necessary (advisories):
  • both inner sills holed, not in prescribed areas
  • oil leaks
What are advisories?
Date tested
27 October 2023
FAIL
Mileage
92,499 miles
Test location
View test location
MOT test number
3916 3776 7953
Repair immediately (major defects):
  • Exhaust system insecure (6.1.2 (a))
  • oil leaks
What are defects and advisories?
Date tested
27 October 2023
FAIL
Mileage
92,499 miles
Test location
View test location
MOT test number
1574 8098 7737
  • Nearside Track rod end ball joint has excessive play (2.1.3 (b) (i))
  • oil leaks
Date tested
8 February 2023
PASS
Mileage
83,161 miles
Test location
View test location
MOT test number
9019 0345 6346
Expiry date
7 February 2024
Date tested
1 February 2023
FAIL
Mileage
83,161 miles
Test location
View test location
MOT test number
1657 3477 6581
  • Exhaust has a major leak of exhaust gases (6.1.2 (a))
  • Emissions not tested (8.2.1.2 (d))
  • Nearside Front Outer Drive shaft joint constant velocity boot split or insecure, no longer prevents the ingress of dirt (6.1.7 (g) (ii))
  • Offside Front Outer Drive shaft joint constant velocity boot split or insecure, no longer prevents the ingress of dirt (6.1.7 (g) (ii))
What are defects?
Date tested
13 January 2022
PASS
Mileage
67,625 miles
Test location
View test location
MOT test number
1902 0519 1811
Expiry date
12 January 2023
Repair as soon as possible (minor defects):
  • Nearside Front Lower Suspension arm ball joint dust cover severely deteriorated (5.3.4 (b) (i))
  • Brake pipe corroded, covered in grease or other material front,rear (1.1.11 (c))
  • Nearside Rear Service brake binding but not excessively (1.2.1 (f))
  • Nearside Track rod end ball joint has slight play (2.1.3 (b) (i))
Date tested
5 January 2021
PASS
Mileage
67,085 miles
Test location
View test location
MOT test number
9925 3182 1826
Expiry date
4 January 2022
  • both nearside tyres cracking in sidewalls
  • Nearside Front Tyre worn close to legal limit/worn on edge 2.5mm (5.2.3 (e))
Date tested
29 December 2020
FAIL
Mileage
67,085 miles
Test location
View test location
MOT test number
4248 4791 8810
  • Front passenger door cannot be opened from inside the vehicle (6.2.3 (a))
Date tested
24 June 2019
PASS
Mileage
66,616 miles
Test location
View test location
MOT test number
4642 5514 7169
Expiry date
29 December 2020
  • both nearside tyres sidewalls perishing
  • Nearside Front Tyre worn close to legal limit/worn on edge 3mm (5.2.3 (e))
Date tested
22 June 2019
FAIL
Mileage
66,616 miles
Test location
View test location
MOT test number
2980 5194 1319
Do not drive until repaired (dangerous defects):
  • Offside Front Tyre has ply or cords exposed (5.2.3 (d) (ii))
  • Nearside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
  • Offside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
  • Main beam tell-tale not working (4.9.1 (a) (ii))
  • Rear Registration plate insecure (0.1 (a))
Date tested
3 July 2018
PASS
Mileage
66,139 miles
Test location
View test location
MOT test number
4592 5052 9607
Expiry date
6 July 2019
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity - dangerous, major, and minor. Find out more.
Date tested
7 July 2017
PASS
Mileage
65,101 miles
Test location
View test location
MOT test number
3763 3088 2088
Expiry date
6 July 2018
Advisory notice item(s)
  • Front Brake pad(s) wearing thin (3.5.1g)
  • Nearside Front Front suspension ball joint dust cover damaged, but preventing the ingress of dirt (2.4.G.2)
Date tested
4 May 2011
PASS
Mileage
64,778 miles
Test location
View test location
MOT test number
8179 4452 1117
Expiry date
3 May 2012
Date tested
28 August 2009
FAIL
Mileage
63,965 miles
Test location
View test location
MOT test number
8221 8004 9239
Reason(s) for failure
  • Offside Headlamp not working on main beam (1.7.5a)
  • Registration plate lamp not working (1.1.5c)
  • very slight play detected in nearside steering rack arm
What are failures and advisories?
Date tested
28 August 2009
PASS
Mileage
63,965 miles
Test location
View test location
MOT test number
1241 1084 9211
Expiry date
27 August 2010
Date tested
26 July 2008
PASS
Mileage
62,242 miles
Test location
View test location
MOT test number
5411 9860 8204
Expiry date
25 July 2009
  • Front Anti-roll bar synthetic mounting deteriorated but not resulting in excessive movement (2.4.G.2)
Date tested
16 July 2007
PASS
Mileage
60,244 miles
Test location
View test location
MOT test number
5417 0709 7147
Expiry date
15 July 2008
  • blow from exhaust system borderline
Date tested
21 April 2006
PASS
Mileage
56,295 miles
Test location
View test location
MOT test number
6746 4191 6156
Expiry date
20 April 2007
Check for vehicle recalls, See if TALBOT EXPRESS L968PAL has outstanding recalls, Show​
Support links​
Built by the Driver & Vehicle Standards Agency
All content is available under the Open Government Licence v3.0, except where otherwise stated
© Crown copyright
May 8, 2021
1,581
3,029
Bedford, UK
Bailey Autograph792F
Since June 2021
To be honest that's ok for an old Talbot, I only every look at the most recent few MOTs as any major stuff should have been fixed to pass.
I'd be looking at getting that welding done on the advisories though, rust will eat through these vehicles!
1,003
6,517
Chesterfield, UK
autocruise Rhythm
Most of my life in one form or another
For that age of van theres nothing on there that id be too concerned about.
Corrosion needs sorting. Can you weld? ( competently) do uou have a welder. Could start to get ecpensive if not.
Upvote 1
May 8, 2021
1,581
3,029
Bedford, UK
Since June 2021
PS, you never said what model the Talbot is, ie yes autosleeper but is it a campervan or motorhome version and what model?
1,453
3,686
Telford
A class Pilote
You keep asking ‘what are advisories’
Simply put these are items the tester has picked up on, tho not an mot failure they possibly could be in the future so he/she is bringing them to your attention so you can address the problems
Emmit
8,073
17,850
Cornwall
Pilote Explorateur
Jan.2014
I would imagine that once the Talbot got to a certain age, the owner, whoever he or she might be
used the MOT test as a yearly "What's wrong with it" and probably avoided/ignored having it
maintained to the best of standards, ie Yearly service, Safety checks etc.
That is why, when it started to age a bit, the Tester found various minor faults that went down as
'Advisories' and no doubt the owner sorted them out and carried on regardless.
suavecarve
7,650
39,357
Surrey/Hants
Rollerteam 685
July 09
The first thing that struck me was 27/10/23 where there were 2 fails with the same items being named but t different MOT stations and the same mileage.
It just seems whoever owned it on that date took it to one where it failed and immediately took it to another within a mile, which one might think they were a bit of a chancer trying to get the MOT passed.
MIleage seems to have been put on in later life and 6 years 2011-7 of no usage but it has been relatively well used since (which i would say is a good thing)
217
728
Burstner i681
Since 2018
I think you might be confusing MOT test number with MOT testing station. The MOT was done 4 months early so it might have changed hands at that time?
217
728
Burstner i681
Since 2018
I m just putting the kettle on, more coffee required here. Cheers
No worries, off topic but a big thanks for your voie verts etc we are off next week to the Rhone/Dolce Via following your recommendations.
Emmit
8,073
17,850
Cornwall
Pilote Explorateur
Jan.2014
You're still in 'Work' mode aren't you?(y)
suavecarve
7,650
39,357
Surrey/Hants
Rollerteam 685
July 09
Just finished nights and it felt like a full moon night ! You ll know what sort of night I had, and like a fool, I have succumbed to overtime on my 2nd night off (tomorrow) so really dont know where I am at the moment, and at time of posting I only had a few sips of coffee.
That s my excuse and I m sticking to it ;)
cruiser
4,231
4,965
northampton
coach built elddis 400
since 1978
I have a 1990 talbot express . I have had it from new. There is nothing on there that should scare you. We have had most of those problems. And we still take our van down to spain and Portugal, nearly every year for about 8 weeks. So go for it.
120
501
Rollerteam746
To be honest for 9k you are going to looking at an older vehicle, this one being 30 years old, you would expect it too have a few issues
