Success with "on gas hob" bread toaster? (2 Viewers)
Apr 15, 2022
176
246
DethleffGlobetrotter
Started in 2005, then took a 15 year break, back in 2022
Been away really the first time off hook up, and the only thing we missed was the use of the toaster.
Anyone have experience of the "on the hob" toaster racks:
This like these?
Cheers.
scotjimland
2,387
10,404
A Woosh bang
cheap and cheerful .. yes they work.. used them when we had no grill
there are other types with a mesh that are flat and lay on the top of the burner
Two on Tour
10,382
51,377
Elddis Autoquest 175
Since 2010
This like these?
Cheers.
Use a dry frying pan. (y)
1,527
2,798
UK
Burstner Travel Van
Few years now
This like these?
Cheers.
Used one once and binned it.
RedFrame
1,297
3,685
Chester
Self Build W907 PVC
Sept 2017
This like these?
Cheers.
Parents had one when I was a kid, the "toast" it produced has never tempted me to buy one in adulthood. :sick:
Red.
696
1,474
Bailey Alliance 66-2
To be honest surprised no-one has mentioned the Ridge monkey at this point. Makes great toasted sandwiches from "untoasted bread" ...
Can confirm the Delta2 inverter/battery we have can run a normal toaster off grid just fine though... this is something we do use as we do enjoy Toast in mornings. It's a bit expensive to just have for Toast though....
717
1,081
Stockport
Tribute 615T sport
17 years + since 2006
This like these?
Cheers.
waste of time as said use a dry frying pan or if its a toastie you want butter the outside of the bread and fry.
these make a great toastie
7,246
20,138
Barnard Castle, UK
Concorde Concerto
Ours is a great bit of kit, best accessory weā€™ve ever bought, it toasts so evenly and uniformly over the whole slice.
696
1,474
looks effective, not seen that before.
It is, but warning, it goes from toasted to burnt in sub 20 seconds, so it's a bit of an art to get perfect toasties out of them, but it honestly produces better toasted sandwiches than our proper toastie maker at home.
H
Apr 15, 2022
176
246
Yea, these are really cheap too. Going to give one a try I think. Thanks for sharing.
Northernraider
27,491
178,489
On the sofa ....
Mobilvetta eurayacht
On and off since 95
This like these?
Cheers.
These are designed to be used with the single burner portable camping stoves you get. I have one and it works quite well on that but us almost useless on the hob in the van as the burner is a lot smaller
3,618
11,615
Leeds - Yorkshire
Paul, tell me whatā€™s even about them, ones just half done and the other has the centre done and both are burnt, and it looks like brown bread, toast was invented for white bread when it accidentally set on fire.
Tombola
4,855
15,777
Merseyside
Rapido 8094DF
Since 2004
Had one once..it was great at making dried bread with burnt bits, I used to set it off and go on my 40 minute morning ride and get back to something resembling plaster of Paris squares that no amount of butter would soften.
If on an aire. Just lean out the window and pass to the German van that parked within 12 inches of you while.you slept and aks them to toast your bread.
