Strange switch (1 Viewer)
Aug 24, 2022
239
609
South Killingholme, Lincolnshire.
Autocruise Gleneagle
I'm a newbie had a wobbly box when adam was a lad
Just found this panel on the nearside seat, there's a switch with an indicator light and can't make what it's for on or off nothing happens even the indicator light is dead 2009 Auotocruise Gleneagle
Jan 3, 2023
380
1,539
Whitby, UK
Autocruise Starburst
From March 2023
Does it work when on hook up?
We had something similar in our T4 van - the switch and socket were both dead but on hook up the switch became active, the warning light came on and the 3-pin socket worked.
Just a thought.
Dec 6, 2011
11,636
25,578
South Wales
Coach built Adria
I would not be able to resist looking behind the fitting to see what’s connected. It seems to have both 12v and mains to the same unit.
Does any of it work?
Dec 6, 2011
11,636
25,578
South Wales
Coach built Adria
Just have took the panel apart and followed the wire, and it's heading towards the cab :rolleyes:
is there connections to all 3 items in that cluster, 12v socket, switch, mains socket?
Puddleduck
12,387
44,010
Scottish Borders
Without at present
On and off for many years.
So I may be well off the truth here but the centre rocker switch appears to make either the 12v or the mains bit active.
If on EHU does the mains switch work?
If the engine is running does the 12v work?
