Sticking down solar panels. (1 Viewer)
Aug 22, 2020
75
108
Essex, UK
coachbuilt
3 years and learning!
Throughout my life I have learnt that there are well established brands for anything to do with motorhomes, polishing your car, painting your house etc etc that some owners will follow without question, sometimes warranted but often spending a lot of unnecessary money (imho), it's good advertising and sales tactics but it's your choice. With all due respect, if you choose to go with one or other brand of sealants and adhesives, you will have to follow it through.
Jun 25, 2021
420
1,211
Nottingham, UK
Hymer A class
Is it really necessary so use both the Sika Primer 206 G+P and the SIKA AKTIVATOR 205? That's more than another ÂŁ50 on top of the Sikaflex 522:oops:
I don't know, I followed the advice, like I say I only used a bit out of either bottle. And if anyone can answer why it has a use by date I would like to know. I would have passed it on to someone who could use it.
Feb 14, 2021
3,674
7,941
Milton Keynes, UK
Burstner Lyseo 727G
19 month year 18000 miles UK, Ireland, France, Spain, Germany, Italy. Campsites and off Grid.
Finally got around to mounting my solar panel today. Roughed up the roof and the underneath of the ali areodynamic mounts, Aktivator 205, Two bottles of sikaflex 522
Not moved the van since. Not sure I will go over 10 miles an hour from now on!
Sandancers
May 29, 2013
2,613
19,374
Tyneside
Chausson best of Flash 10
Several years now
Any idea how long you have to leave the sikaflex 522 before it is fully cured ?
Feb 14, 2021
3,674
7,941
Milton Keynes, UK
Burstner Lyseo 727G
I seem to recall people saying not to move for 24 hours. I must admit I haven't checked as I'm not intending going anywhere soon.
DPSharp
4
4
West Mids, UK
Romahome
The last details I now need to consider for fitting of the solar panel involve finding the correct adhesive to fix down the supports for the solar panel. I DO NOT want to use any screw fixings into the roof of the MH at all.
Having been aware that many people use Sikaflex I tried phoning them, on the UK number, to speak to a technical person to ensure I got the best adhesive for the job, I got passed from pillar to post and never got to speak to anyone who could advise. I tried emailing their technical enquiry email, no reply.
So basically, can anyone advise on their preferred adhesive to fix down the solar panel supports, type shown below, and also to a website or official youtube video from the adhesive company showing their correct method of preparation and assembly to use the adhesive ?
Sikaflex is very good ct1 is even better though. Comes on clear too.
Sandancers
May 29, 2013
2,613
19,374
Tyneside
Several years now
I have already bought the 522, but I'm wondering why when I eventually got to speak to the Sikaflex technical man and explained my job he didn't say to use ct1 if it is better ?
DPSharp
4
4
West Mids, UK
Romahome
Two different companies possibly? Probably not going to praise a rival product.
Dec 3, 2021
288
385
Surrey, UK
6m Campervan
I have two panels stuck with 522 on my roof. They've travelled over 8000 miles so far and still stuck fast.
Feb 14, 2021
3,674
7,941
Milton Keynes, UK
Burstner Lyseo 727G
Just given mine a good tug and they seem well stuck. Gonna be nervous when we take them out on the motorway next Friday though!
Feb 14, 2021
3,674
7,941
Milton Keynes, UK
Burstner Lyseo 727G
Further reading is highlighted that 252 is also recommended (not sure if that is older than 522) and also that 291i is better than 522!!!!
Steve-N
160
237
Cheltenham, UK
Fiat Ducato Camper
2nd Campervan since 2019
My van is a Ducato, so with ribbed roof, which means that I intend to fasten the panels down on the long edge at 1640 long. I still have the option to use short brackets on the forward edge where the ribs allow in order to help to stop the panel lifting. Hence my request for the amount of sticky stuff required to stick them down. I quite like the tip to use 3x2 angle as this will give me a larger area to stick down.
I have the same van, and due to the roof ribs, I have made up some hard plastic 'spacers' to infill the rib troughs, stick these down with adhesive first, then the panel supports on top.
May 2, 2014
2,255
4,612
Washington
Hymer B 584DL
17 years + 35 tugging
I used puraflex 40 from Toolstation on western approach 👍🏻
Also give the plastic mounts a good key on the bottom I also drill some 6mm holes along the edges so the puraflex comes through then mushroom them over.
Sooooo clean :giggle:
TheBig1
17,649
43,471
Don't block the channels or you will trap water and accelerate any rusting
The only other important point not already made here is galvanic reaction caused by different metals in contact, like untreated steel bolts in aluminium
2x2camper
851
2,006
The channels are already blocked by the roof vents. On mine water cannot flow out of the channels between the front and back vents.
PatE460
Olney, UK
E460 besscarr
2018 went to Europe lived in my van 2 years
On my current Bessiccar E460 and my earlier van Ifixed a 220W solar panel, this was the biggest panel I had space for. I used the same method for both I used 3M VHB Tape (Very High Bond) This is the stuff used to stick panels onto the outside of sky scrapers.
But you have to make sure both surfaces are a solution clean. Follow the instalation to the letter.
You only have to drill one hole to get the cable in. You can cover that hole with Cable Box with a weather proof seal.
Dec 18, 2017
76
70
Lowestoft UK
Bessacarr 524
since 2003
I think if the advice you got from the professionals said 522 then I would take there word for it. There isn't enough of a price difference to worry about, and you feel confident with what you have.
I have used Sika for years, and never had any issues.
My question for the person that posted CT1 would be, who said CT1 is better. I know it is good, I have used for all sorts of jobs. If it helps, its great for sticking the soles back on my shoes. Be happy Sandancers.
Jul 29, 2013
9,076
18,674
Salisbury
Hymer B678DL A class
since 2011
This works well👍Sunstore solar recommend it🤔
Aug 22, 2020
75
108
Essex, UK
coachbuilt
Amazon product ASIN B0B69JT31S
Are these the ones that we are recommending over abs plastic corner brackets.
Would just two of these be ok for my 170w victron panel at 670mm wide and just shy of 1500mm long?
These are the ones I used, several different suppliers but all pretty much the same, ally with a big ribbed footprint, the panel I used them on was a little bigger than yours but cannot remember exact dimensions, I used 4 sets, 1 for each end and 1 for the sides, I also infilled the smaller gaps left with abs pieces and 4 abs on each corner, the leading edge of the panel was completely infilled so acted as a wind deflector, this minimized areas where air could be forced under and cause potential lift but allowed adequate ventilation under the panel.
Belts and brace but then I'm not a "real" engineer!
GaryGavlaar
163
54
Bessacarr E695
670mm is the width of my panel and 670mm is the width of the ally bracket so will completely fill the front and back side so hopefully have the same effect.
Jul 22, 2020
333
669
Newent, UK
Etrusco T6900
changing a load of things again
I wouldn't use those plastic brackets, nearly every panel that falls of has been fixed using plastic brackets.
Far better to make or buy some aluminum brackets.
If you do use the plastic brackets you need to make sure you use the correct grade adhesive that is compatible with both surfaces both plastic & the roof material.
agree the plastic ones are rubbish, ali angleall the way
Steve-N
160
237
Cheltenham, UK
Fiat Ducato Camper
Same as the ones I used, my panel was 1470mm long, and used one at each end.
Only squeaky bum bit was drilling a 20mm hole for the cables :oops:
(and before anyone says I used way to much adhesive for the TV ariel, that was installed by Elldis . . nice job - not !!)
GaryGavlaar
163
54
Bessacarr E695
They look like plastic ones?
Apr 17, 2023
Adamo
The issue I see is plastics degrade very quickly with sunlight whilst aluminium will not.
Nov 4, 2011
5,964
39,521
Uk
When I bought a couple of panel off Techno (RIP) he had made aluminium angle brackets and had fitted a dome headed screw under brackets to act as spacer, it worked well
