Status 530 fitting (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Just covering the less detailed instructions for you , pictures always tell a better story
Beware of wires! always drill from inside and remove the inner skin & filling before drilling the outer skin.
These will just push aside when installing mast sleeve
position base so holes will miss any wires
drill pilot holes for screws ( the 3 short ones supplied were just a bit too short so I replaced them )
Fit the cover and gaiter using the 3 long screws provided
view inside
Angle adjustment fitting is still used regardless. Mine has a flat roof so fitted to suit
tighten up the screw collar and drive in the screws
Fit the mast through the roof and fit the locknut inside
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
a very neat and tidy job:thumb:but i would only let a pro to do mine:Doh::ROFLMAO::ROFLMAO:
dug
May 28, 2011
77
35
Cheltenham
ducato maxi tdi 24'
newbie
I've drilled so many and without anaesthetic :Eeek: :thumb:
I see you've got the spare(bulb bit)on the solar controller going to the vision plus how does this work at night?i thought it was just spare volts from the sun, and does this mean i can cut off the big 12v adapter that goes from my vision plus to my invertor,and just use the same as yours.ie direct to 12volts via a fuse.?
I was going to try and post a photo,but after seeing the quality of your work mine lookes like a monkey has been let loose with screwdriver!!!!:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Thanks for a clear and concise How to......Dug:thumb:
43,388
49,817
the 'aux load' terminals are a regulated output from the batteries for accessories Dug.
only a small load can be applied...just 1 or 2amps load
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
The load terminals (bulb symbol) will carry the regulator rated current. Mine will carry 20amps
during the day it will take power from solar or solar and battery. At night from battery only.
The regulator(most do) has a voltage cut off to prevent the battery being over discharged, usually a little over 11volts.
Just need to be sure that the wiring between regulator and battery will carry the load.
I always wire direct to battery (4mm minimum) so avoids using existing converter wiring
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
The Status amplifier
The "Really Useful Box" left in picture houses my auto changeover RELAY rather than humming contactor I used to have.
I'm not often on hook up so not had chance to prove it works OK yet but works fine in N/C position feeding 3 of my 230volt sockets from my 350watt sterling pure sine inverter.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Could a mod move this to TVnSatellite pleez? and delete this post at the coming together :thumb:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
a very neat and tidy job:thumb:but [HI]i would only let a pro to do mine[/HI]:Doh::ROFLMAO::ROFLMAO:
That's a change in tune Chris, two weeks ago you were not going to let the pro's do a job, you talked of setting up on your own, just to save a few quid..........
...........a super job there, nothing does as good a job as a gifted amateur and lets face it we are talking professional or amateur here not expert versus cowboy.
.....not sure that all makes sense what I mean is I'd rather have a gifted amateur than a professional cowboy......ah balls you know what I mean:roflmto:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Techno really useful clear pictures thanks
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
i was being sarcastic!:Doh:
