Starfire 2006 - how much weight will the roof take? (1 Viewer)
Sep 24, 2013
1,318
753
Norwich
Carthago A class
Since 2014
I'm fitting a solar panel shortly and need to know if I can put any weight (me - 65kgs) on the roof so I can clean up the Sikaflex from the panel mounting plates. It would also help with cleaning the roof. I just can't seem to reach the middle bit from a ladder. I have no idea how thick the roof is or how it is constructed. It does seem to have a non slip finish to it as if it was designed for someone to stand on. Tha tmay of course be a false assumtion.
Chris
21,058
279,719
None
10 years
65kg's?
I salute you. I was 60kg when I was 13.
I am sure the roof will take 2 or 3 of you.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If this is a pre Swift starfire EDIT (of course it is) it will be GRP outer skin with 5mm ply underneath which then sandwiches polystyrene between that and the papered ply ceiling.
Your weight isn't an issue.
stevec
Sep 24, 2013
1,318
753
Norwich
Carthago A class
Since 2014
So looks like it's ok to put my weight on it. I'll spread some duck boards around though just in case.
An interesting picture Techno. How did you cut the hole without chopping through the wires. Some sort of magic trick?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes I do lots of them. No need for duck boards! I spent lots of time on our Starspirit roof.
Explained here
Broken Link Removed
stevec
Sep 24, 2013
1,318
753
Norwich
Carthago A class
Since 2014
Thanks Techno. Our van already has one of those antennas. Whoever fitted it put it right on the joint between the front roof moulding and the flat roof section. It obviousl;y leaked as they had to put loads of silicon round the base. A bit of a mess really. Complete lack of forethought!
I see you put your solar charger in one of the top lockers . How far was the run to the battery? I was considering doing the same but it would leave a two meter plus run of cable to the battery. Not sure what volts drop at 10A (max o/p of my charger) on 4mm cable would be. I'm not sure if I'd every get 10A from my 120W panel though, at least not in the UK. Do the screws holding your kit hold ok in the wallboard?
Is that a battery manager box on the far left?
stevec
Sep 24, 2013
1,318
753
Norwich
Carthago A class
Since 2014
Just to complete this post. I have just put the solar panel on the roof and I haven't fallen through. although I spent most of the time on all fours there were times when I had to walk upright across the roof. No hint of sagging and no nasty creaking noises. Now I know that I can send the wife up there to give the roof a good scrubbing!
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes the roof is solid but the high chassis means the body rolls more especially if stood up so not advisable or you could just fall off :LOL:
Techno
Jul 28, 2010
15,475
20,756
May 2010
Pictured is our first van the Starspirit in my early learning days :LOL: 200 watt of solar and every conceivable extra. Happy days and memories.
