Squeaky Squeaky Squeak - ARRGHHH!!! (1 Viewer)
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Caravan owner moved on to Motorhome
Hello Folks..
My 794T has developed a new high pitched squeak that drives me bananas! I can only describe the sound as the kind of squeak you'd get if you took the head of a nail or screw and started wiggling it against a pane of glass.
I think I've tracked it down to the oven area. I thought initially it was being caused by the inner glass panel inside the oven door... nope.
Anyone else have/had this irritating noise? It even happens when the wife isn't in the passenger seat :)
Nov 22, 2020
66
80
London
Auto Roller 746
I'm a newbie
šŸ˜… I had the most annoying squeak too! I soon found out it was a plastic leg on the inside of the remis blind in the front cab and it was rubbing against the window. A strip of doubled-sided foam from a pack of Command strips did the trick. Ahhhhhhhhhhh, Bisto
PP Bear
7,851
28,978
Kent, UK
Auto Trail Dakota SE
My blinds vibrated and squeaked like crazy, until I stuck some padding to stop them from rubbing together.
Weirdest part was that it sounded like it was coming from behind me, not in front.
Also, everything gets wrapped to prevent the noises, as I can't stand em šŸ˜¬šŸ˜„
AndyPK
5,028
14,050
Cirencester
Noneā€¦ā€¦..!
Motorhoming since 2015......
Are you sure itā€™s not a mouseā€¦..Where?,Under the stairā€¦Right there. A little mouse with clogs on! :ROFLMAO:
Sorry,I couldnā€™t resist another chance to sing that song :rolleyes:
Songā€¦ā€¦ā€¦?!?o_O
Feb 21, 2016
4,925
29,781
Uk
C class
Since 2017
Songā€¦ā€¦ā€¦?!?o_O
probably 1960ā€™s,Val Doonican or somebody like that.
I saw a mouse,where? There on the stairā€¦ā€¦.blah blah A mouse lived in a windmill in old Amsterdam.
If I was tech savvie Iā€™d put it on hereā€¦ā€¦but aint! But you could!? :giggle:
AndyPK
5,028
14,050
Cirencester
Noneā€¦ā€¦..!
Aaaaaaghhhhhhā€¦ā€¦ā€¦ā€¦..!!!
M-J
Jan 15, 2019
2,651
6,303
Cambridgeshire, UK
Rapido 986F
Getting there!
I had this for ages and checked everything internal time and time again before I found it, turned out to be the brackets for the fresh water tank under the van had play in them and wouldnā€™t go any tighter. I had them loosened them off, added some rubber shims and retightened.
M-J
Jan 15, 2019
2,651
6,303
Cambridgeshire, UK
Rapido 986F
Getting there!
Another good one to check is the over head lockers that open upwards, they sometimes squeak when closed (wiggle up and down)
syelad
31
18
Leeds, UK
Bailey 79-4i
Iā€™m a newbie - since 2021
Hi Paul
Did you ever find the cause? We have what I guess is the same annoying oven area squeak in our 794iā€¦..
Paul Wilkins
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Hi Paul
Oh my.. should I say 'Welcome to the Club'?
I thought I'd nailed it by wiggling the internal glass panel in the oven door as that has the two elements that sound like they are rubbing together. Next time out, I'm going to remove the internal glass panel when travelling to rule it out completely.
Now that you've mentioned you're getting the same irritating high pitched squeak, that says there is a design issue. I've worked in the automotive manufacturing sector and they have teams of people finding these squeaks and rattles. They then do a 'root cause' analysis and trace it to a loose bolt or an ill-fitted part or rubbish material.
I'd like to think Bailey would be interested but judging by the reports I read, I think they just 'bang em out' and don't really care that much about quality.
I'll let you know how I get on :)
Feb 16, 2020
2,321
3,171
KT15.
Sunlight. T66. 2019.
Absolute beginners.
Fill the oven with rolls of Kitchen paper, and a towel around the wire shelf, see if that knocks the decibels out of it.
We use our oven as a larder, placing tinned goods in a plastic basket, that also helps absorb the soundscape.
Mike.
syelad
31
18
Leeds, UK
Bailey 79-4i
Hi - thanks that would be great.
Agree with the Bailey problem, itā€™s such a shame as we love the van, weā€™ve only had it about a month and the layout is perfect for us and it looks great.
Weā€™ve had to take it back to the dealer for about 10 annoying issues, some of which are ā€œhow the hell did it leave the factory like thatā€ issues including a hole in the top of the large table and front window blinds that donā€™t close. Also floorboards that creak like something from a horror film. The dealers repsonse was, oh yeah we know about that one, and that one, and that one. The squeak reminds me of one we had in our old T5 which I tracked down to the rock and roll bed. Much easier to track down In a smaller van while you are driving!!!
Feb 16, 2020
2,321
3,171
KT15.
Absolute beginners.
If you've got a squeaking floor already I would be questioning whether the floor had delamination issues going on already, least ways I'd want to make dammed sure with some written correspondence from the dealer that they were was also making sure it was not a problem!!!
Mike
Paul Wilkins
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Mike.
Hi Mike. We have nothing in the oven, all of the shelves are out and we wrap the hob in tea towels too. The noise is also 'intermittent'. Bang over a pothole and it starts up, bump over another it stops.
Paul Wilkins
May 14, 2018
331
430
Lincolnshire, UK
Autograph 794-T
Yeah the floor, if you're talking about the one where the table is stored. I've sorted that with felt pads (gift from the gods).
Other than this 'orrible squeak (which has only kicked off fairly recently) I love the bus. Taking it back off to Germany next month, it soaks up the miles.
