Hi. having trouble sourcing a speedo cable for my 1996 swift kontiki boxer motorhome. i've found LHD cables but can't find RHD.
any tips would be much appreciated
i'll consider that if i can't source the cable but i'd prefer a straight swap which would be less faff.Take the old one to a cable makers plenty around the country, they will make a copy
Sorry didnāt notice thatthe ones at coastal are for LHD. they're a different length. thats the issue i'm having is finding a RHD cable as its longer
i think i may have found one, just waiting for a reply off the seller to be certain. the length of the LHD ones are 1500mm but RHD are 2200mm. the RHD one is also nearly twice the price!!!Sorry didnāt notice that
yeah thats the one i'm looking at, just emailed the seller to be 100%. nearly double the price of the LHD ones! ah well, such is life.expensive, but if needs must
Fiat Ducato Peugeot Boxer Citroen Relay RHD 2200mm LG Speedo Cable Gearbox 94-02 | eBay
Especially manufactured to suit RHD at 2200mm Long. Fiat Ducato Peugeot Boxer Citroen Relay RHD Petrol -1994 - 2002. FIAT DUCATO 230-244 _ all BZ 10/14 q.li. RHD (Right Hand Drive) Speedo Cable from Gearbox to Speedo.www.ebay.co.uk
cheers for the link. i'll check it out.speedy cables will make one think they are in swansea or cardif now used to be in london
i think thats what the problem is in my case, the old one is roughly 1500, haven't removed it yet but have stuck a tape measure along most of its length, when i took the speedo console off the cable was all twisted and mangled behind it as if it had come out and got hooked up on something, (possibly because it was too short and under tension).From experience in older ducatos Peugeots the shorter cable will work but if your old one has been removed measure it and see how it goes against the 1500mm
i did message them asking if they had the rhd version in stock so i'll see what they come back with. cheersCoastal motorhomes may not list it, but maybe able to source it, or provide you the exact part number to assist your search. Iāve always had fantastic service, and help from them, with good prices too.
well i just had a message back regarding the cable from an ebay seller but its a no go, mine happens to be the rare nut type, (had to be the rare one of course) , so i will try the guys you recommended. i've just checked their location and i'm working 5 minutes away from them next week so will just drop off the old cable so they can copy it.Speedy Cables | Automotive Instrument Repair - Mechanical Cables
Speedy Cables manufacture, service, repair and calibrate automotive instruments and gauges worldwide. Products include speedometers, tachometers, ammeters, fuel gauges, oil pressure gauges, clocks and all types of mechanical cables.www.speedycables.com
