Spare wheel hanger fitting (1 Viewer)
AllyMoHo
34
16
A Class Pilote
I’m a newbie
Hi Guys n Gals
I bought a spare wheel hanger kit for my 2014 Pilote Reference G690 A class on ducato chassis.
currently on my back underneath the MoHo comparing the holes in the chassis to the supplied bits.
Not sure if I have a kit that will do several vehicles!! Anyone done the fitting and has photos of under the vehicle of it fitted.
No instructions provided with the kit. 4 x bolts, 4 x rivet nuts, 2 flanged nuts supplied.
Any help would be appreciated. I have a rivet nut set to fit the unit. Just need a bit of clarification. Cheers in advance.
Feb 14, 2009
1,374
3,329
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
Depending on your chassis you may need to buy some longer bolts at location A in lower photo to go through chassis , as they often supply a different fixing. Let us know if you need more help
AllyMoHo
AllyMoHo
34
16
A Class Pilote
I’m a newbie
The 3 other brackets are identified with..H20, G20 and J20. These pics are of the cross member behind the rear wheel and the member in front of rear wheels showing the obvious holes for fitting.
AllyMoHo
AllyMoHo
34
16
A Class Pilote
I’m a newbie
Hi Vanderek, thanks for the reply. The top pc seams to match my underside as it is a flat surface. Just gauging the single threaded hole on forward crocs member (rear axle member) looks about M6. Quite a tight curve to the lowering cable isn’t it!! Just need to tap the main threads to clear any unnecessary gunk and then fit rivet nuts.
AllyMoHo
AllyMoHo
34
16
A Class Pilote
I’m a newbie
So ha ha outer rivnut fitted. The one closest the the chassis won’t allow the rivnut tool in the locate before fitting. Maybe use a steel sleeve through the chassis and fit a long bolt and nut. As the hole in the chassis is hexagonal I should be able to fit a sleeve to prevent crushing the chassis!!
AllyMoHo
AllyMoHo
34
16
A Class Pilote
I’m a newbie
All done, thanks for the input folks.
Jun 16, 2017
325
583
Bridlington
Pilote P650GJ
Happy to help
Here you go this is on my P650GJ fitted it myself.
Jan 6, 2019
32
27
Suffolk
Burstner TD690G
Since 2018
Rather than the rivet nuts you can use M10 x 100mm bolts straight through for the winch mount. it worked a treat for mine. Use Nyloc nuts mind with washers.
voltair1238
Van conversion
I have just bought the kit and I am about to do this. What sort of tool did you use to insert the rivnuts? Some of the holes look very close to side members.
May 1, 2015
580
430
Caerphilly
Rapido C86 Auto
Since 2014
Hi, don't need a specific tool just bolts and washers. If you search on Youtube there a few videos of people fitting them this way. I used the bolts that came with the kit pus an 8mm nut and a washer.
Patrick
voltair1238
Van conversion
Patrick
Hi Patrick. Thanks for your reply. Yes I have seen those videos, I was just interested in what people had done for this job in real life.
Simon
Jan 27, 2018
2,690
2,138
Northampton
Rapido & Bongone
The hex holes are for hexagonal rivnuts
https://www.ebay.co.uk/sch/i.html?_...eDesc=0&_odkw=mate+hex+++aa+rivnuts&_osacat=0
Apr 18, 2021
189
700
Lincolnshire Wolds AONB, United Kingdom
Sunlight Cliff 540
Since 2008
I've just fitted mine and done exactly the same. Don't know why Fiat don't provide M10 bolts to do it that way, and it's far easier and quicker to fit. As there's no substantial weight associated with the winding gear housing, using nylock nuts and just nipping them up works just fine. The wheel suspension bracket at the centre of the chassis crossmember uses M 8 bolts, and the nuts are already welded inside the box section. I used washers on these, and applied a little bit of thread lock to the bolts as well. Both the 2 x M10 and 4 x M 8 bolts I used were stainless steel.
