Solar Panels - Which Sikaflex? (1 Viewer)
Mar 12, 2012
1,395
1,612
Bridgend, South Wales
Just started!
So I've got all the components and when the weather gets better I'll be fitting my solar panels.
I'm a little unsure as to which Sikaflex to use to stick the panel support brackets to the roof? My panels are large 200w and I have two, I have 6 support brackets for each panel, 1 for each corner and two for centre of each of the long sides.
As the panels are quite heavy, what's the best way to stop the Sikaflex being squashed out from underneath the brackets? Would a few matchsticks do? They'd create a gap of about 2mm between the base of the support bracket and the roof. This space would be taken up by the Sikaflex of course.
Any tips gratefully received :)
StitchUp
Mar 12, 2012
1,395
1,612
Just started!
Are you also using a mechanical fixing ?
I wasn't planning to. The footprint of the six brackets is quite large and most of what I've read on the forums suggests that a mechanical fixing, screws etc, are not necessary. The only screws would be those used to fix the brackets to the panels. I always take the advice of those more experienced than myself, especially SWMBO :ROFLMAO:
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
I helped a fellow member fit 2 pannels to my Motorhome,or should I say held the ladder and passed him things.The brackets were screwed to the panels then the unit was sat on roof to get the best position.This was marked and the areas where the brackets met the roof were wiped down with white spirit.
Then some sikaflex 512 was applied and the pannels placed,no matchsticks used and the pannels pushed down well.This was last summer and within an hour of fitting had a forty minute drive home,after many miles since still stuck solid I check them every now and then as a precautionary measure.
I've 2 90 watt pannels on roof and 2 110 amp batteries and been wild camping in Scotland for 2 Weeks in summer and 4 days longest away in winter so far .Never out of power and batteries fully charged from pannels.
Regards Vlad .
StitchUp
Mar 12, 2012
1,395
1,612
Just started!
That's great to hear :Smile: Thanks Vlad.
Some say Sikaflex 512 and other say 291 - hence my confusion!
Vlad The Impaler
1,633
2,227
Rutland
He has fitted a few and an expert that quoted me close to a grand for the set up I have was also going to use 512.Infact I got a idea of what I needed from the experts sourced the bits on eBay and with the help of a FUNSTER saved a packet.
:thumb::thumb::thumb:
Vlad.
Mar 26, 2009
8,163
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
John,
This thread Broken Link Removed outlines all that is required - See Andy's (Techno100) post (#7) with pictures etc.
I bought my Sikaflex from .
6,547
148,993
Pickering
PVC the PUG
252.... Just to really confuse matters :Doh:
Broken Link Removed
Ralph....:thumb:
StitchUp
Mar 12, 2012
1,395
1,612
Just started!
Thanks guys.
Yes, I've purchased several tubes of 512 off Ebay but then got confused when others used 221 etc. Was just looking for the definitive answer as I'll likely need more 512 if that's the right stuff.
Feb 22, 2008
12,265
45,051
Norfolk
Nearly Tugging
Since 2004
I think I am a "belt and braces" safety first type, I have two 120w panels on my roof and used ss screws and adhesive.
At 70mph on a motorway a flying solar panel would be decidedly unsociable :Eeek:
