- Apr 18, 2021
- 189
- 700
- Sunlight Cliff 540
- Since 2008
I wanted to fit a solar panel to my PVC, but was apprehensive about drilling through the van's roof for the cables. A little bit of investigation inside the van, coupled with some lateral thinking, and I've managed to get the cables into the van via the front rooflight surround.
Having taken off the Dometic Heki perforated vents on the sliding blind structure, (they're a push/click fit,) it reveals 3-4 screws holding the blinds in place, remove these, and the blinds pull off quite easily as a complete unit. Removing the clamping screws for the Heki on the side nearest to the sliding door allows you to ease the roof lining down, and from there I was able to ascertain that I could pass cables diagonally to the void behind the control panel above the sliding door. From there, you can pass cables through a small gap into the overcab storage area, which is where I'm going to position my Victron MPPT.
The cables from the leisure batteries to the MPPT pass behind the plastic cover for the step and light switches, and can be tucked neatly behind the trim running up the side of the B pillar. There is a small gap between the rear of the overcab storage shelf and the 'arched' trim that goes from B pillar to B pillar, and I was able to push the battery cable up through this to meet up with the MPPT.
I've yet to fit the panel itself (it will be bonded to the roof with Stixall, and has a front spoiler attached) but the internal work is just about finished. The footprint of the panel can be seen in the photo - it's half the box that it arrived in!
On my van, I'm fitting a 200W Craig Solar panel (I went for the biggest wattage I could, based on the available roof space, and it measures 148cm x 68cm.)
The good thing about the Heki, is that when it is fully closed, it covers the entry point for the cables, but you do have to take this into account before drilling the holes, so that the fully closed roof doesn't interfere with the cables.
I'm happier knowing that my roof won't have any holes in it, and if the solution I've chosen ultimately fails for some reason, (although I can't think of one right now...) it will be cheaper to replace the Heki at approx. ÂŁ500 rather than the whole roof!!
