Snipe 2 Error (1 Viewer)
Crampy
53
20
Tarporley, Cheshire West and Chester, UK
Fendt K500
30 months
The dish won't go to the Home position. When I press OK to seeing Astra 2 the dish starts to move then says EL ERROR and then switches off.
Hope it folds when I start to move or I'm going home with it extended!
Nov 2, 2008
461
377
Lincolnshire
PVC, S&L Iveco
45 years
Had a similar problem with ours where it wouldn't go back down and it turned out to be the home switch on the base of the mount, the rubberized switch that the dish presses on when it goes right down. Might need to poke it a couple of times to free it. It's caused by the switch not releasing when the dish rises so confuses it.
C
Crampy
53
20
Fendt K500
30 months
Yes, have pressed the HOME button. The error is actually EL LIMIT ERROR then switches itself off. I've tried the MODE to do the error check for EL but that didn't let me close it down.
Dan and Jan
572
4,524
Scotland
Between Vans
On and off since 2000
I take it you have switched it off and on to clear it? This is from the instructions.
The Coops
1,822
34,476
The Fylde
Adria Compact DL
Yes, thank you
Do a GPS location re set that often worked
C
Crampy
53
20
Fendt K500
30 months
I physically unplugged the 12v cable from the Controller rather than just switching it off and left it overnight. On re-plugging and switching on, pressing the Home button parked the dish perfectly.
I'd forgotten the bloody remote anyway, but the Wife doesn't know that!
Lenny HB
53,620
150,714
On the coast in West Sussex
Hymer B678 DL
We did tell you to disconnect the power, silly boy, listen next time. :LOL:
Ken Warby
3
Elddis
I have the opposite problem. The dish will not come out. In the test mode it comes out goes round and back then tells me all is OK. When I try to search again it says EL error then switches off.
irnbru
13,515
31,144
Glasgow
Benimar 264
11 yrs
Is your software up to date?
Gellyneck
9,263
18,389
Scotland
More than toes wet now!
Have you tried pulling the power lead out leaving for a while, then retrying?
irnbru
13,515
31,144
Glasgow
Benimar 264
11 yrs
Can it be updated via a samsung mobile phone.
Not to my knowledge. If your control panel is round d/l the update file onto a usb and insert the usb into the C/P and follow on screen instructions. It was very easy.
Lenny HB
53,620
150,714
Hymer B678 DL
One note on upgrading it won't reconise large memory sticks certainly won't work with a 64gb not sure about a 16gb I use an old 4gb one.
Gellyneck
9,263
18,389
Scotland
Yip, but from memory I might have used an 8Gb one(?).
napessnr
3
Hi there, mines is stuck any idea where I could buy one of these.
Nov 2, 2008
461
377
Lincolnshire
PVC, S&L Iveco
45 years
Probably giving it a few pokes will free it off. Ours was returned to Germany for repairs but I suspect if you strip it down you will find a standard type of micro or push switch under the rubber cover.
barron
3
Swift
Assuming a "C" type controller this is how you do it.
Hi,
I have a Snipe 2 with a C type controller, I need to update it but I don't have XP nor does anyone I have asked, can you please advise me how I could get the update file.
Thank you.
Kind regards.
Barron.
Lenny HB
53,620
150,714
Hymer B678 DL
Hi,
Thank you.
Kind regards.
Barron.
:welco:
You download the file from the selfsat site, it's a zip file.
Not sure why you mention XP you only need to download the file unzip and load to the root directory on a USB stick.
