Smev Oven Going Ou (1 Viewer)
Feb 25, 2020
247
490
PPVC Autocruise Alto
I'm a newbie
Hi all any thoughts as to why a five year old hardly used Smev grill / oven will not stay alight ?
It ignites straight away, Flame increases with the control knob but within minutes goes out !
I have recently installed an lpg underslung tank, Trauma filter etc, everything else is working just fine ?
Jun 10, 2010
8,519
20,233
Shrewsbury (sometimes)
N&B Clou Liner MAN
leave the door open for a few minutes untill it gets going properly
Feb 25, 2020
247
490
I'm a newbie
ok will try leaving the door open longer, not sure re thermocoupling no experience of gas cookers please advise ?
Jan 8, 2013
8,490
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Make sure there's a reliable flame playing onto the safety thermocouple. It must be kept hot to open the gas valve.
Lenny HB
53,476
150,190
On the coast in West Sussex
Hymer B678 DL
Sounds like the thermocouple to me also.
The thermocouple is the flame failure device, the tip of it is in the flame and all the time it is heated it keeps the gas valve open.
Feb 17, 2017
459
1,924
Herefordshire
A Bit
Most MH cookers have thermocouples fitted which shut the gas off if the flame goes out, you would normally hold the knob in to maintain gas flow until the thermocouple gets to the correct heat, if the oven stays lit whilst holding the knob in and then goes out very shortly after you release the knob it may be a faulty thermocouple, try holding the knob in longer than usual before releasing it as if it stays lit until you release it then this will highlight the problem for you
Apr 22, 2018
6,825
12,585
Herts.
Adria Coral lowline
If you look at the gas ring on your hob you will see two extra bits sticking up at the side of the ring. One is the igniter and the other is the thermocouple. Hopefully that explains what you are looking for. These often just need to be bent (gently) into the flames.
Jun 30, 2011
7,241
20,133
Barnard Castle, UK
Concorde Concerto
Is it definitely going out, ours was doing the same after 10 to 15 mins although a top gas expert said it is not going out but has reached temperature so the flame goes down. We still think it's going out hard to check can't see a flame at all but he said there is one but it's very low because it's reached temperature.
What number is the knob on, the highest one?
TheBig1
17,635
43,358
with the oven off, remove the shelf and stick your head inside. Down the bottom at the back you will see the burner and a long cylindrical thermocouple on a brass pipe. This is held into the flame by a small bracket and sometimes they get dislodged
