Slow cooker (1 Viewer)
43,392
49,878
If the inverter is running off the engine battery.
If its running off the hab battery the split charge may not be able to provide enough current to keep the battery charged.
R
Robert Clark
We ran ours off a teeny tiny inverter plugged into the cigarette lighter
43,392
49,878
Just checked ours.... 190 to 200watts.
Thats around 16amps and unlikely a split charge will deliver anywhere near 16amps.
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
Our solar would cover that with help from the engine --------we we run slow cooker or remoska while driving quite a bit, never had the slightest hint of low batteries
Feb 10, 2013
774
1,249
plymouth
Sprinter
off and on 30 years
I understand now I always use mine on hookup. Just had :rolleyes:another moment
Lenny HB
53,772
151,301
On the coast in West Sussex
Hymer B678 DL
No problem for a German van with correctly sized cabling, no chance with a Brit van.
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
Would it cook running off an inverter whilst we drive. It could sit in the sink and stew nicely.
MrD is more practical. Have you considered the real cost of generating electricity via the engine? Only use electricity to cook when it's available from EHU.
JockandRita
11,491
150,421
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Yep, no problem. We have often done a ham/gammon joint in ours, whilst motoring along. (y)
We use silicone elasticated cord to keep the lid in position, and free from rattles.
Cheers,
Jock. :)
Apr 27, 2008
11,856
14,103
Eastbourne East Sussex
Hymer low profile
Since 1972
We've used ours from inverter from leisure batteries while driving, but only when the sun is shining. The split charger cannot cope with this and the fridge without solar support.
The slow cooker doesn't use as much as its rating as once hot it switches on and off on the thermostat.
With a b2b charger you should be OK
Shrimp
May 27, 2015
3,999
33,741
Bedfordshire, UK
Hymer B584
Long time
I use a slow pot but not whilst travelling as most times I need slopot on for longer than the journey.
JockandRita
11,491
150,421
Lincs/Cambs border
N+B Flair 8000i
Our Cookworks slow cooker is rated at 200W, and runs off our 300W inverter. (y)
Cheers,
Jock. :)
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
Why mess with a slow cooker?
I think MrD's thermal cooker is a better solution:
No smell;
No danger of spillages or need to clutter the sink;
No need for an inverter, convenient socket or lead across the van;
No need to switch between Hi/Med/Warm;
... just heat it up and leave it to do its stuff.
Oct 12, 2013
812
899
Filey
N and B Flair
Since 2014
Can’t get to grips with mrd’s. We have our slow cooker with us, it’s been used almost non stop this last 3 months in Morocco, for lamb, mince dishes and of course goat and camel. (y)
jollyrodger
6,282
26,426
Devon/Cornwall
'Obby
Since 1968'ish
I have a small slow cooker ,run it on the move ,via inverter .
on low twin 110a batts topped by solar .
Not a problem ,except cooking smell coming from rear and a 100 k to go :(
Lanerboy
1,363
2,206
midlands
Carthago 4.9 superior
not sure about in the MH whilst driving but I now use a king pro pressure cooker instead of my slow cooker does exactly the same job but in a 10th of the time meat falls apart and only takes an hour also no smells untill you open it up and if it is possible to use whilst driving (not sure it would be) no chance of a spillage as lid is sealed tight
Does anyone know what a pressure cooker would consume power wise
