Size of cable? (1 Viewer)
Sep 11, 2018
323
366
N Wales nr Chester
Citroen Relay pvc
16yrs
I’ve a 100w solar panel which is 12m from the Victron MPPT 75/10 controller to the battery in my shed - can I use standard 2.5mm cable over that distance ?
Dec 2, 2019
3,617
7,813
Amersham
van conversion
Since 2019
For 12m run, 2.5mm2 cable it will be safe as it will only carry 6.2A at 100w load but, the drop will be 7%, with 6mm2 cable same distance and same power, the drop it will be 3%. And this is at 18v from panel to regulator.
Lenny HB
53,724
151,125
On the coast in West Sussex
Hymer B678 DL
As Raul says 6 m sq would be much better but if it's only for a battery powering lighting in your shed if may not be too much of a problem
In summer when you have plenty of sun and long days a 7% loss (0.42 amp) may not worry you too much and in winter the panel will only be producing say 2 amps the loss will only be 0.12 amp so not enough to worry about.
Sep 29, 2007
805
1,167
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
I’d also consider a 2nd panel in series, higher voltage.
