- Apr 18, 2021
- 189
- 700
- Sunlight Cliff 540
- Since 2008
I have attached some photos of a small, but significant modification I've made to my 2 x 240v sockets above the 'cutlery' drawer. It bugged me that with a kettle etc. plugged in, it wasn't possible to open the drawer underneath the sockets, with either, or both sockets in use, as the kettle lead etc. was in the way. So I took the sockets out (checking no 240v power attached to the van first!) and re-oriented them as per the photos. One photo shows LH socket done, with RH socket still in original position, the other 2 shows the job done on both, so that any leads from kettles etc. are horizontal and not vertical when plugged in, and you are able to open the drawer underneath without unplugging.
It's quite easy and doesn't involve removing wires or anything, just 10 screws (4 for each socket, plus 2 cable clips behind the panel.) As the sockets are square, it's possible to fit them in any one of 4 different orientations. The spring loaded cover for each socket simply pops off, revealing 4 fixing screws on each socket. It took me less than 30 mins to do it, including a bit of 'feeling' for the cable clips behind the panel, removing the drawer (very easy) and checking with a small torch and mirror to check that nothing else was in the way or got disturbed. I replaced the spring loaded covers in their original orientation, to prevent any accidental catching of them in any other position.
