Sealant for rooflight (1 Viewer)
wizza
175
117
Essex
low line
8 years
i have a 2010 pilote which has a fibaglass roof i am fitting a fiamma fan over french bed area went to remove existing rooflight and held in with sealer adhesive. Cut old sealer removed old rooflight, can i seal this with non setting which is what i bought for the job and used on my hymer but that had alloy roof or does it react with the fiberglass Thanks :)
Aug 6, 2013
11,960
16,579
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Use the normal non-setting - it works fine. Easiest is the stuff that comes on rolls of varying width.
wizza
wizza
175
117
Essex
low line
8 years
all fitted now thought it would be ok had to cut the old one out what a pain.
Had some on roll left over from last project so i used that thanks tonyidle
wizza
wizza
175
117
Essex
low line
8 years
Thanks scotjimland had some left on a roll, cant beleive pilote used adhesive it seems like the same stuff i just fixed my solar panel with
The other vents are the same.
