RV electrics (1 Viewer)
Apr 29, 2012
312
287
Holmfirth
1990 Gulfstream RV
30yrs
Has anyone any idea why when I put the sidelights on, all the clocks and gauges read low, eg, fuel tank down by half etc. cheers.
43,450
50,421
just a guess but sounds like a bad earth somewhere and the lights are earthing via the instrument panel lighting and associated wiring circuits
often seen on trailer lights were one or more lights may dimly illuminate when the brake or indicator lights are operated.
caused by trailer brake lights or indicators earthing through another, unrelated bulb
steevie
Apr 29, 2012
312
287
Holmfirth
1990 Gulfstream RV
30yrs
Thanks for that, I will run a good earth to the lights, and see if that solves it.:thumb:
bandit
221
114
Widnes,Cheshire
7 years
lights dimming,
Afternoon all,from my tempory camping spot at Widnes Tesco DC,pitch right outside main gates as you do.I had a problem very like yours,The light switch was shorting out and taking every thing else with it,then it Finally burnt out coming down M6in early hours.I manage to do a bodge with to fine screw drivers,The wiring at the back of the switch had worn out,and was causing a hot spot,New switch Fitted new wires and its fine now.Hope you get sorted,all the best,...'the bandit:thumb:
Jul 28, 2010
1,710
617
The world
Small car
Once Duncan. Www. Starspangledspanner.co.uk
Tell him make year model of your RV
He will know and get any parts you need
