Rookie gas question (2 Viewers)
Feb 21, 2018
101
77
Hampshire
Coach built
Fairly new, since Sept 2016
We have a Cadac barbeque. We run it off those (tiny) gas cylinders. Is it possible to run it off the main red calor gas cylinders? If so what connectors/regulators(?) do we need?
Thanks!
suavecarve
7,599
39,144
Surrey/Hants
Rollerteam 685
July 09
I presume you bought a cadac with a screwfix in the middle underneath that you put the little blue containers onto ?
If so unsure that you can attach a bigger gas cylinder to it, but it might be possible. Best of luck
Two on Tour
10,406
51,606
Elddis Autoquest 175
Kannon Fodda
2,603
8,061
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
There are two types of Cadac, low pressure (LP) and high pressure (HP).
HP has the small portable canisters screw directly to the underside of the burner into the threaded valve under the burner.
LP and you connect the Cadac to a gas supply with a detachable hose. If you have a LP Cadac you can connect that to the BBQ point (gas outlet) on your Motorhome.
For those with a LP Cadac you can get a hose with regulator allowing you to use the HP portable cartridges screwed into the regulator https://cadacuk.com/product/threaded-cartridge-regulator-assembly-en417/
I am not aware that you can get the low pressure of a motorhome BBQ outlet upscaled to work with a HP Cadac. I'd expect the internals of the HP burner wouldn't allow enough gas to flow.
Feb 14, 2009
1,374
3,329
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
You need to check if your Cadac is low pressure or high pressure. Check your model on their web site , you change change one way with an adaptor, not sure about the other way.
Two on Tour
10,406
51,606
I posted this post #3 of this thread just in case all of you saying that you can only run a HP Cadac off a screw in canister missed it.
JaneyBMotorhomer In Hants
Feb 21, 2018
101
77
Hampshire
Coach built
This is what it looks like, it has long legs and the cannisters sit on the ground, the orange pipe being connected to the blue burner bit. It is a Grillogas model number 740-50. I think it only works on the small cannisters though as there are no instructions for connecting the calor gas cylinder.
Dec 2, 2019
357
1,712
Redcar/Cambrils, Spain
Now Tugging
More with boats than Moho
It looks like there is a regulator attached to the small canisters but doubt if this would fit the propane bottles that you have in the van. Look at the links that I posted in post #7.
Hamilton Gas will be cheaper than Cadac, they also have a good technical team that you can call and are really helpfull
