Request to fiat ducato owners (2 Viewers)
Jul 8, 2008
1,140
1,475
Weymouth, Dorset, UK
c build
24yr
hope this helps if you can see it
no 1 is sensor temperature
no2 thermo switch
no3 thermo swich overheating
this is for a2.5
citroen &peugeot from 1994
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
hi this is what it looks like
Thanks again for your help , picture is bit hard to màke out on my phone of the layout of where it is , tho I will try make bigger on laptop , is it showing it in the thermostat housing ? It's so weird I can't see anything like in this picture with wires going to it buddy , will try again Tomoz thanks again for your help
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Sorry Nunny, been away. I will check my own 2.5 in the morning, and get back to you. (I think the photo of the red button is the restriction indicator for the air filter).
lugnutt
1,190
466
wednesbury.westmidlands
autotrail apache
10 years
hi i had both my censers changed after temp gauge went to the top the breakdown man said it could be ether so change both he took of the large hoses and they were underneath. cost was 80 euro's as i was in France at the time also took 2 days to get new parts :Sad:
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Thanks all , still not managed to blow up the photo on laptop for clearer look , shall have closer inspection over weekend , I shall order some new parts too , thanks again for everyone's help and input so far on this
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
If their underneath the big hoses that could be why ime strugling to see any electrical connectors coming from the sender ?
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
FOUND IT!!! It lives behind the top mounting of the take-off arrowed.
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Cheers tootles buddy , is it right down back ? This is what I see from their can't see out electric cables wise
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
What the hell is THAT??? Mine has a sender unit there. No pipe into the back of it. Can you see where that pipe goes??
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Lol hang on ile get pic of that bit , I have noticed this right on other side of engine with what looks to be a broken bit if wire in top
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
When you say 'other side', do you mean towards to cam belt cover??? And, what's that below it?? A pipe, or another sender???
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Think you cracked it. Any sign of a loose cable knocking around? It might be blue.
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Its on the left side as I face it so passenger side as mine is left hand drive can't see any loose cable knocking about other than a broken green cable buddy , does it look like a sender
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Yes, certainly does. Try this. Bare the green wire back to metal, wedge it against the manifold. Turn on ignition, and watch temp gauge. If it shoots up to VERY HOT, that's your wire. You will have to be REALLY CAREFUL getting that sender out, its tapped into alloy. Spray the exposed threads with WD, go get a brew, then use a socket that fits it correctly. Take it nice and slow, you dont want to strip the thread. You might lose a spoonful of coolant, but keep the top up bottle cap on, then you wont lose much. I would put some copperslip onto the new threads before you fit the unit.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Sorry mate, the one you found looks like the baby, not the one with the pipe attached.
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Ok cheers I will try tomorrow night when lighter , tootles I was expecting a spade type connector on top this looks like it had a wire just solderd to top , thanks for all your help , keep you updated
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Just realised I posted a pic of the probable sender , ment to pst this when mentioning where the pipe went
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
The spade connector rotted off mate,. Was there nothing at the end of the green wire?? Will have another look at mine if poss tomorrow. Will get the colour for you, if I have a sender there. The other one with the red cables attached looks like an electrical switch.
43,377
49,773
this is a long shot but i have a vague recollection that the sender is on the back of the water pump.
looking from the side it is to the rear and on the engine side of the pump body or in the long metal pipe running from the pump along behind the cylinder head.
its been a very long time since i had a 2.5 ducato so could be mistaking it with something else.
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Worst case situation if no wire I can buy a fresh after market gauge with wire as long as that's right place to put new sender , so not all bad
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Yes, but you need to find out how the thing works first, which will tell you what, if anything, is knackered, before you start buying new kit. I will take a look, and get back to you. Our truck is in storage, so it's a bit of a journey. Leave it with me.
PS, the wire is part of the loom, it comes not with a new gauge.
nunny666
Apr 10, 2014
234
58
huddersfield
Fiat
newbie
Thanks for going out of your way on this , really appreciated ,
