Replacing RV Aluminium roof (2 Viewers)
Tribblehunter
3
Hampshire
RV C class
A few years van life, but not on the road
Hi all.
Newbie to the forums here.
Recently obtained a Fleetwood Jamboree Rallye 1989 RV and trying to find where to get a roll of aluminium to replace the roof. Found a supplier stateside but unable to locate anywhere in the UK.
Anyone point me in the right direction?
I was going to Liquid rubber the roof but after prepping it found far too many holes from corrosion. It spent many years as a liveaboard in europe in its past life and suffered from a lot of trapped condensation.
Jul 4, 2018
1,215
1,596
Bristol
Weinsberg
A few years.
T
Tribblehunter
3
Hampshire
RV C class
Hi Mister B.
I have not fully decided yet. Still exploring options.
I liked the idea of ripping off the old Aly, removing the rotted roof, sorting out the gaps with expanding foam, laying a new marine ply layer then rolling and bonding the Aly sheet.
I'll be pulling down the ceilings at some point and putting in a vapor barrier of some sort. If they did that when they built it I guess this would not have happened!
I have been told I can get a fiberglass "roll" similar to the aly but have not found anything yet.
T
Tribblehunter
3
Hampshire
RV C class
Thanks Clivefog.
I did try them online, but they did not seem to do sheets large enough. Ill send them an email.
busbuddy
1,294
2,917
leicestershire
swift suntor 630G
since 1994
When we reshelled my german coachbuilt a few years ago we could only find painted van roof aluminium on the roll 2m wide so if you need it wider 🤷‍♂️
Eltheringtons used to be a good supplier, contact was wendy thacker
We found that normal aluminium suppliers had it on the roll 3m wide but it was quite thick, even an extra 0.2mm can weigh a lot on a 7m length
1,532
6,282
NW Surrey
LHD Hymer exsis-i
How about speaking to a domestic roofing company? We had a fairly large flat roof done in fiberglass a few years ago after it came highly recommended. Also there is EPDM rubberised roofs. If I was in your position I would speak to the manufacturers first, not the contractors, and discuss the possible implications of movement.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Motor Home Fun
Has a sister site called RV Owners Club.
RVOC.
That would supply top quality information on all things RV.
Many Fun members are RVOC members too
Discount membership is available if you join both
FUN and RVOC run rallies and impromtu meets throughout the year in normal times
Both welcome members fron the Rv An Fun membership.
Popty
136
243
Oxfordshire, UK
American RV,
Since 2018
Check out truck/trailer body shops, when they replace trailer roofs they get aluminium sheets on rolls up to 40ft long and 8ft wide
