Replace the existing grill with an oven (2 Viewers)
Jun 18, 2018
72
63
Suffolk, UK
Adria Coral 600sl
since 2019
Hi all, has anybody any experience of replacing a grill with an oven in their van? We have an Autocruise Accent with a grill which we don't use and we would like to replace it with an oven which we would use a lot. If anybody could point us in the right direction it would be much appreciated. I have attached a piccie of the current setup.
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
I have a bread bin / cupboard just like that.....and offen think the same thing👍🏼
Jun 17, 2019
479
620
East Yorkshire
Just looking
One a newbie
We had same grill and wanted the oven, the opening was to small!
We are now looking at adding big a drawer instead.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
What are the measurements of the gap into which it needs to fit?
32,700
66,738
Its not just about the unit size itself but also ventilation as an oven could get very, very hot, much more than a grill so you may need to also install an external vent too.
34127
The Thetford Spinflo duplex oven does not require external ventilation but does need air gaps above and below and to each side which makes the space required quite a bit bigger than the oven itself.
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
That looks like a nice grill.
There are other ways to cook without an oven.
We decided, after a lot of thought, not to have one and have more drawer space instead.
In smaller vans, compromise is required.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
The gap does look very small. I think you'd probably need to break into the cupboard below, which might require considerable carpentry skills. It also looks decidedly narrow.
32,700
66,738
Another thought, if you always use sites with EHU just take a mains powered small oven instead.
Aug 4, 2019
1,923
8,510
North East Riviera
Low profile
Enough to Survive
I’m fortunate to have a vent behind the grill.
I’ve seen these grills replaced with a microwave on a few occasions.
But I’m not sure if the change is a worthwhile addition.
I normally just use the CAD......no.....gas griddle / stove with a lid 😉😂
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
You might just fit in a Dometic OV1800. Hard to tell without dimensions. You'll probably lose the top drawer and have to stick in a bit of a filler panel, but again hard to tell without measurements.
Sep 29, 2009
975
672
East Anglia
Roller Team
I think that's a smev 20 litre grill same as we had in our rollerteam waste of space. Replaced it with larger 30litre smev oven by removing air gap and a little bit of feterling. Works great use it alot. It came with fitting kit that gives a small air gap all the way around. Only concern with yours is the left hand side a flat piece may be needed.
Sep 10, 2012
2,139
3,801
worcester
Sunliving van
Removed one of those from previous van and did what minxy suggested above.
Small electric oven from argos which left space all around for ventilation.
32,700
66,738
I've just had a quick shuftie at the size of the grill compared to the grill/oven and the latter is taller and wider so unless you want to do a lot of work to the cabinetry I don't think it's gonna work.
Aug 18, 2011
12,162
18,034
derbys
AUTOSLEEPER SYMBOL
Buy a Romeska,,Does most things an oven does.BUSBY
18,049
48,218
If you are happy to lose the drawer below the grill I am sure it can be done. We have a SMEV oven and grill which use a lot. You just need to check the dimensions and find one which will fit. You will probably need to add a new shelf to support it.
S
Jun 18, 2018
72
63
Suffolk, UK
Adria Coral 600sl
since 2019
Thanks for all your thoughts. The available space is too tight to fit an oven in currently. I am looking at replacing the whole kitchen unit with a custom made one including an oven. We are mostly off grid so EHU solutions are a no go. I will post when we have made a decision. As usual, thank you all for your help.
demem56
4
Hi all, has anybody any experience of replacing a grill with an oven in their van? We have an Autocruise Accent with a grill which we don't use and we would like to replace it with an oven which we from besttoasterovenguides.com would use a lot. If anybody could point us in the right direction it would be much appreciated. I have attached a piccie of the current setup.
Yes going to share in detail. :p
Jan 8, 2013
8,494
11,535
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I specked the Spinflo oven and grill for my new van because its much more powerful than the Domestic's.
It also seems much better quality.
If I was fitting out the complete kitchen I would go for the complete unit Spinflo Triplex Caravan LPG Cooker (Hob, Oven & Grill) £499
