REFILLABLE GAS BOTTLES (3 Viewers)
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
does anybody know what happens when the due date is up on refillable gas bottles do you take them back to the supplier and do you have to pay to get them changed im looking at buying a pair off second hand bottles but they only have 7 years left on them anybody had this problem any help appreciated
Feb 16, 2013
19,760
52,159
uttoxeter
ambulance conversion
50 years
Don't know how old you are mate but I'm afraid 7 years would probably be enough for me,no worrys
Nov 3, 2013
3,172
9,411
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi.
I had a couple of the red safefill when they came out,good bit of kit,i was under the impression that when the date was reached,you just had them tested and re-certificated........I" Could be wrong"........ Often am,unlike my wife....... That's me out of here!!!
Tea Bag
Mar 26, 2009
8,169
11,249
Yr Wyddgrug
Hymer B678DL
Why not call the manufacturer and ask them.
gpz
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
thanks for all your replys i have e mailed gaslow i found out that after 10 -15 years you have to return the gas cylinders for replacement for a charge but it does not say how much so hopefully gaslow will reply
Dec 2, 2010
1,060
2,321
Hollywood, Birmingham.
A Class Laika
Since 2011
Don't know about gaslow but industrial cylinders are tested every 5 years, pressure and visual tests. I believe Calor are also tested this way. There is a european pressure test directive for all pressure vessels to be tested periodically. I would have thought that Gaslow cylinders would only need retest and the 14 year figure seems overlong. I would carefully check the cylinders for a set of stamped numbers and letters indicating the last test or the original pressure test.
Googled it and these guys specialise inlow pressure gas cylinders -:
(y) http://www.southstaffsindustries.com/index.html
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Tea Bag,
You more or less have it.
gpz,
The norm is 10 years between inspections for propane cylinders.
(That's inspection by an authorised body.)
The gas company will have to pay for the inspection, hence the charge involved.
Some cylinders may be authorised for 15 years, so the gas man has it spot on.
Whether 10 or 15 years will depend upon the manufacture date and authorisation.
There are slightly different rules for composite cylinders, but I would agree with Chaser and Tambo.
Don't worry about it for 6 years or so.
Just professional curiosity:
Could you check with Gaslow to see if the cylinders are of composite materials, and can you check the cylinder to see if it has a mark "P15Y" on it?
Cheers
gpz
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
i got a reply from gaslow this morning basically saying as the first bottles are only ten years old and they have a 15 year date stamp they cannot tell me what the cost will be so still dont know thanks for all your input
