Rear view camera through the wall fitting PART II (3 Viewers)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Continued from Broken Link Removed
Having carefully measured the centre line I used the 28mm hole cutter supplied with the camera which makes a clean job in the GRP
Internal cable protection
view with bike rack folded down
mentaliss
654
306
Lancing
rear view camera
next time your Council friendly dust truck is outside your house take a good look at it these vehicles they are all fitted with bullet type rear, side and front view cameras plus the reverse warning siren plus multi screen monitor they have been using these systems since Blair gave Brussels the nod to implement another compliance that this country has to adhere too :Smile:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Continued.......
This was how it was apart from it had turned considerably rusty and the reverse camera was no good with bikes onboard.
and now with two seperate 120 degree cameras
Unfortunately monitors don't photograph very well but just to give you the viewpoints ( actual picture is very good )
Top camera
Bottom
I've contacted the seller of the top one about getting me a 90 degree version which will be more suited to rear view rather than reversing.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Once again nice photographs Andy thank you for taking the time and trouble :thumb:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Thanks John
Seller is getting me a 90 degree unit (delivery two weeks) ÂŁ33
Can also get me 60 degree but I'll try this first.
Ridgeway
3,672
6,207
Lausanne
NiBi Arto 85E
Andy was it a simple case of connecting in the new camera on a spare AV input ? I assume you have 2 inputs and 1 already in use with the top camera ?
I have a similar issue and my top factory fitted camera is good for reversing but nothing else even after playing about with the angle, this idea may solve it for me.
Also is your top camera activated when reverse gear is selected or is it on all the time ?
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I originally had a dual camera with two seperate cables to my monitor so I have only substituted the dual for two singles.
Rear view on AV1 reverse on AV2
The cameras are fed by the monitor and come on with the ignition, I manually select AV1 or AV2
Ridgeway
3,672
6,207
Lausanne
NiBi Arto 85E
OK thanks.
So you avoided the nice cable run task from back to the front, the part I love most:cry:
