Rear marker lights (2 Viewers)
BazM
13
Carioca 656
Newbie
Hi does anyone know where the upper rear marker lights are fed from on a 2005 656 on a Ducato chassis? Is there a separate fuse for them which I would have thought unlikely, all other side and markers work. Tried tracing the wires they seem to run through the roof on the offside over the shower and then....? Thanks for reading Baz
Aug 6, 2013
11,959
16,576
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
All the ones I've seen appear under the rear of the van connected to the rear light wire. Check the light fitting itself first though - they aren't the most robust devices.
BazM
BazM
13
Carioca 656
Newbie
Thanks Tony ,no been underneath, side and rear feed into chassis to re-emerge?? Holders not that bad but done the usua. Think they come down shower wall and past dinette into fuse box behind drivers seat which I had already checked! Might have to give that another visit!
Annoying to spend time on something so trivial when there's other jobs, but once you've started...? Regards Baz
