Rear cycle carrier (1 Viewer)
Jan 6, 2017
23
9
italy
low profile
i'm a newbie
I want to fix a rear cycle carrier to my 2009 Chausson Welcome WS, 6 metre, fixed rear double bed. Am thinking of a Fiamma Pro for 2 ebikes, each weighing 26kgs.
Any experience from members with same van, or general tips on fixing the carrier. Unlike newer vans, mine does not have any permanent fixings built in.
Thanks.
TerryL
6,218
8,240
North East
Low Profile
Do you have a towbar? Could use a towbar mounted rack without having to drill the back panel. Check weights though as those bikes are quite heavy.
6,039
32,328
East Anglia
Kontiki 669
That’s what I have,a Thule towbar mounted rack,and takes two electric bikes no problem (y)
801
1,410
south yorkshire
since 2004. Tugger 10 years on and off
I carry two E Bikes on my fiamma pro.Weight is the problem.Not on the rack but Depending on the height of the rack .Mine is at a reasonable hight but any higher and it would be a struggle. If i was starting afresh i would fit a towbar and use a Tuli bike rack.
11,721
25,774
South Wales
Coach built Adria
As already mentioned by others above, not only the weight on the back wall of the van but lifting a 26kg bike to probably around shoulder height can be a limiting factor.
B
Jan 6, 2017
23
9
italy
low profile
i'm a newbie
Thanks for the input everyone. I was thinking of perhaps the model Pro C which is more compact than the Pro and fitting fairly low down to do away with high heavy lifting of the bikes. I do not have a tow hitch.
2,516
11,002
Remove batteries and that will reduce the load considerable... depending on size up to 5kg each !
We also have a Thule tow-ball rack for 2 e-bikes.. it's so much easier than the lifting even lighter pedal cycles onto a Fiamma rack on the wall which we had previously .
I would be very wary fitting a rack on the back wall with 50kg of bikes .. , it will need bolts with spreader plates inside..
