My father's motorhome, based on a 1997 Renault Traffic 1400D needs a replacement axle. Does anyone have any idea where he can find one? His garage hasn't had any luck to date. Many thanks
A Renault Trafic is the same as Vauxhall Vivaro and Nissan Primastar..... I believe!!It might well be worth investigating whether the axle from a Citroen or a Fiat van might fit. I think they share a lot of parts.
Not sure a Citreon relay is compatible to renault trafic.?Have you contacted breakers?
10 seconds on Google brings this match up............and there'll probably be others if you want to take the time to look.
Citroën Relay 1400D LWD 2.5 Diesel 1997 Breaking Spares Parts Wheel Nut | eBay
<p dir="ltr" style="margin-top:0; margin-bottom:0;">!£1.20 WILL BUY YOU ONE WHEEL NUT! </p> <br> <p dir="ltr" style="margin-top:0; margin-bottom:0;">Citroën Relay 1400D LWB 2.5 1997 Diesel Breaking Spares Parts Wheel Nut</p> <br> <p dir="ltr" style="margin-top:0; margin-bottom:0;">5 speed gear...www.ebay.co.uk
Thanks for the response. I'm not wholly sure as they live in Sussex and we are in York. But it sounds as if the bearing went when they were driving and ended up destroying the axle?? To be honest I'm going on what my Dad has told me the garage has said.... French ebay might be a good option.Just curious as to what the problem is with your Dad's axle (I am a nosey begger tho !) ?
The one on my '05 Master is basically just a piece of pipe, not a lot to go wrong ?
I had a quick look on French ebay and there were a couple of vans being broken and they mentioned postage to Royame Uni ?
Indeed. My point really was that the best chance to get one for a vehicle of that age was to look at getting one from a breaker. Although as previously mentioned it's usually bearings and seals that wear rather than the axle structure.Not sure a Citreon relay is compatible to renault trafic.?
