Pressure washer (1 Viewer)
May 26, 2023
426
1,190
East Midlands
Swift c404
Just about to order a cordless pressure washer for the van and was wondering which one other members use? I have a full blown mains washer, however, too cumbersome for regular outings and the risk of using too high a pressure, was also wondering if a foamer was a useful addition. Txs.
Apr 17, 2016
6,059
35,877
South Coast
White One..
3 years….
All down to the operator if you don’t know what you are doing don’t do it!!
Have a Worx cordless but when at home I have a new Karcher K4 and it’s pretty powerful.
I snow foam and shampoo with it but turn the nozzle down when rinsing apart from a little bit of water coming in above the Hab door never had any water inside.
Pretty sure driving through rain at 60+mph is more of a test for the decals and seals😁
1,646
13,768
Kings Ripton, Huntingdon
RP Rebellion 2 2024
60 + what Mr CC. Know all about your right foot 🫣😜
127
180
UK
Semi integrated
I have the
18V ONE+™ HP Cordless Brushless 41Bar Power Washer
I find it very useful. Batteries also work with my other tools. Lasts a sensible time too with the 4ah bay
It’s not to powerful to do any any damage but powerful enough to do the job of assisting my cleaning
JaG
Oct 30, 2008
1,379
1,467
Chesterfield
Autotrail Cheyenne
Since 2008
a few weeks back i bought the Lidl version it lasted all of 10 minutes. so have difficulty reccomending it.
havent been able to come to terms in deciding whether to buy another one or not.
I have the Aldo one, had it three years. I use it a lot for graffiti removal and never had a problem with it. About 20psi I think.
3,889
5,295
The City of Henlow
Adria Supreme
Since 1980
Why be nervous about power washing, take advantage of being able to redesign you decals. With a little determination you could :wasntme:redesign your van by removing some or all of your decals. Start afresh with your own designs, they might be successful.:worried:
Quantric
9
8
Waterlooville, UK
Autosleeper
Started Feb 2022
One point to make. We all know what weathering is, when the weather ages things. Basically that's what a pressure washer can to your paint work. Also forcing it's way into parts that the actual weather would never get too. Brushes and a bit of effort never hurt anyone.
gwyntaxi
1,153
1,047
,Swansea
hymer starline 655
42yearscaravanning&motorhoming
I would Never use a pressure washer on my van, I normally use a hosepipe, when using the car washes abroad because they only have pressure washer types I do use them But I stand well back from the van so that it only gets the weak end of the spray to rinse the soap off,
Pressure washers damage the seals and force the water into every nook and cranny.
funflair
19,513
31,053
Guisborough
MORELO palace
since 2012
Slightly contradictory post ;) you say you would never use a pressure washer on your van and then go on to describe how you use one (sensibly) when abroad.
4,790
25,380
B&NES
Van Conversion
since 2007
I found that the garden hose with a Draper nozzle attachment gives more pressure for washing the PVC than the Worx Hydrashot does. It isn't a true pressure washer like the 230V corded ones. I would call it a power washer you can use with a bucket.
My main use for the Worx one is with the optional bottle attachment so I can rinse off bird poo quickly and without hassle.
1,671
4,640
Hampshire
Chausson 640 welcome
Since October 2019
I have a number of Makita cordless tools - so bought a Makita pressure washer unit and utilise the same batteries/ charger. Good quality and sufficient for giving the motorhome a wash when touring in the EU. It can be connected to a mains water tap via standard hose/tap connectors and/or fed via a short hose from a bucket of soapy water in the first instance. I also take my Makita hand held vacuum cleaner and a tyre inflator with us. They are brilliant and the vacuum cleaner runs forever off a full battery.
if you plan to build up a range of cordless units it is worth thinking about which manufacturer you will choose initially - such as Makita, Bosch, DeWalt etc as the batteries and charger are normally the expensive part. Thereafter, the base units are relatively cheap. At home, I have the usual range of Makita cordless stuff like, drills, saws, etc. which I have built up over time as a keen DIY person.
You don’t work for makita do you ;-) ??
2,350
3,223
KT15.
Sunlight. T66. 2019.
Absolute beginners.
Best thing, wait for a day like today, [ raining] miserable to do, but no rinsing required, just make sure you have a really stable step ladder for the roof area, and one of those telescopic poles to help reach across the van roof, and the bucket of detergent on the floor.
Mike.
4,156
9,332
South Lincolnshire
Rapido 7065+
Broken most bits now
The ones we used to use were 40,000psi, mind you there were for hydro demolishing concrete so may have also stopped paint 😂 ( We did actually strip more modern non lead paint with them occasionally aswell)
43,423
50,186
That’s amazing, I haven’t seen a cordless one that can go above 650 psi, my Karcher might, however, not seen a cordless in this range
Well, it is portable but rather heavy...... It's petrol powered.
I was pointing out I would never let a pressure washer anywhere near a motorhome
funflair
19,513
31,053
Guisborough
MORELO palace
since 2012
That sounds pretty dangerous to be fair ;) wash your boots off at the end of the day and cut your toes off :LOL:
6,059
35,877
South Coast
White One..
3 years….
Have come across this a few times over the years, first was a 30m dia final settlement tank in a sewage works that had lifted and they cut the base out to expose the rebar.
They had a mini digger with an attachment on the end for that.
Second time a bridge abutment what had been built wrong so 100+ cube of concrete had to be cut out and leaving the rebar😁
Very dangerous bits of kit for sure and expensive 😳😳
486
2,160
swift Kon tiki 794 G
Argggg don’t say pressure washer, I just spent 3 days pressure washing my yard, my Moho my car, my villa and anything in the yard…. Argggghhhhh my poor back..
Tombola
4,926
16,021
Merseyside
Rapido 8094DF
Since 2004
Pressure washers are handy..
But if you have a lot of paving to do, and have blackspot or algae try
Sodium hypochlorite (black spot general grime)
And wet and forget for algae green crap.
Spray em and leave em..work a treat
486
2,160
Ceramic tiles, dirty rain, hate it..
152
149
Suffolk, UK
Rapido 9048DF 2016
Resurrecting this thread as I have just bought this year's Lidl cordless pressure washer.
Will try to remember to report back.
First brief test.
Seems to work OK from water in a bucket.
Nothing spectacular.
Seems pretty good on a hose from an outside tap.
First impression is that it is nearly as good as a mains pressure washer.
However the trigger doesn't quite shut off the water flow when you release it.
I don't know if this is a bug or a feature.
I had the bigger battery - 4Ah - and it lasted a while, but not enough for a major job.
I messed about washing some paving, then washed about half a car, and then it died on me.
I have a 2Ah battery as well so could probably managed a reasonable size clean.
My main aim is to use it with a bucket on the roof of the MH.
Also to see if the foamer helps at all.
We shall see.
