Poor Radio Recepion (1 Viewer)
B
Beanstick
My Radio Reception On My Autocriuse Is Very Poor Can Anyone Help Me With This Regarding Fitting A Different Aerial.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Hi Beanstck
It helps to know base vehicle
If Fiat based its a known problem and the usual cure is to fit a small rubber wing mounted arial (rubber duck)
Geo
Jim
Ringleader
Jul 19, 2007
36,694
132,711
Sutton on Sea, UK
Adria Panel Van.
Since 1988
In most Fiats the aerial is in the wing mirror and the reception is terrible in all but the very strong signal areas. A stick-on windscreen aerial might help, I just put a cheap halfords stubby whip job on the wing, it worked a treat.
Pammy
Aug 3, 2007
881
152
Mansfield
AUTOTRAIL CHEYENNE
3 years
The radio drives me mad in our Autocruise as it keeps switching itself off after 20 minutes. :Angry:
That problem has a fix too its relativly simple re wire jobby:thumb:
Castaway
192
60
Darlington
Gone back to tugging
40 years
Or do what I did and buy a proper radio! (The standard unit is cr*p!)
I discovered my Castaway had no aerial at all, just a bit of wire in the door pillar! Fairly useless!
I fitted a Halfords 'Rubber Ducky ' type and it's fine now.
B
Beanstick
Hi Beanstck
Geo
PEUGEOT2007 BASE VEHICLE. HAVE YOU HAD ANYTHINK TO DO WITH SCREEN AERIALS.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Yes Iv'e disconected quite a few and fitted proper ones
Geo
Just to add
An expensive quality radio deserves a quality arial
a cheap radio needs one
