Pilote G600 (1 Viewer)
Jul 13, 2011
287
37
Stoney Stanton
since 2010
Any idea what the tyre pressures are for Pilote G 600. I have been told 72 front and 79 rear which seems rather high
KeithChesterfield
528
1,234
Stand Road Chesterfield
Low Profile
Since 2010
What make of tyres have you got and what are your axle weights?
If you don't know you need to go to a weighbridge, cost about a fiver, and then ask the question again.
:D :D :D :D
Jul 7, 2012
5
Leicester
Since 2008
We have a pilote g600l and the tyre pressures all round are 55, set by SMC when we picked it up. We have winter tyres 225/70R15s fitted. Not sure if this is correct though - hopefully others will know better. Hope this helps.
Adrian
DuxDeluxe
14,671
73,080
Planet Zog
A woosh bang van
since 2008
Tyre sizes are 215/70R15 Continental.
Mine has been uprated (G690) but having put it across the weighbridge and calculated loads then it is 60 at the front and 75 at the back. Each van is different but with real life axle weights from a weighbridge it is very easy to calculate
KeithChesterfield
528
1,234
Low Profile
Since 2010
My Piloté tyres are the same as yours and, after weighing the front and rear axles fully laden in 'holiday' mode, the Continental tyre recommendations give me front pressures of 51psi (3.5 bar) and rear pressures of 61psi (4.2 bar).
I've used these settings for three years and there's been little wear and a comfy ride.
But until you know the weights on your MH it's impossible to give you accurate advice.
:D :D :D :D
