That is interesting..... We had a couple of minor gribbles and an annoying squeak from the drop down bed all of which were very easily fixed. Due its second hab check in a couple of weeks.Oooo, hate to tell you this but we have a 2014 Pilote G600 & the build quality is appalling
That doesn't look good - the only fault similar to the above is the creaky bed which took me about 30 seconds to fix with some lithium grease. Hasn't made a sound since. The hab door has been known to come unstayed but it hasn't presented a problem.Extracts of an email sent to UK Agent for Group Pilote, last year.
Only answers so far:
'Pilote has established itself to be the best French motorhome manufacturer' & he will respond to my email 'given the constraints of time'
Design Faults
The habitation door stay is mounted too close to the door hinge, therefore it does not hold the door open.
The gas bottle storage locker fills with spray when the vehicle is driven in wet weather. This has caused the Gaslow bottles fitted to corrode.
The heating duct that runs to the offside cab outlet is both not insulated and is around 6 metres long. This means that the air is cold by the time it reaches the vent.
The bed is noisy, when simply turning over during the night.
Assembly Faults
The habitation door window leaked.
The near side radio speaker wire was cut, so no radio.
The cab front to sidewall joints do not appear to be sealed, this allows outside air to blow through the dashboard & blind area.
There is inadequate draught proofing in front of the dash.
The fresh water tank was not secured in the under seat locker, allowing it to move.
I discovered this when I had to remove the tank, in order to access the heating ducts. These had been fitted without retaining clips & had come apart, thus the heating the fresh water tank & little else.
The water pump is fitted in too high a position, the seat base presses down on the pump when this seat is occupied.
The dashboard and blinds make a considerable amount of 'clicking noise' when the vehicle is driven. Fixing this remains a long tedious work in progress.
Heater compartment. Whoever fitted the heater positioned it so that it rubbed against both the locker door and the furniture board in the rear left hand side of the compartment. The boiler gas supply pipe was poorly positioned, hard against the sink waste pipe, after several weeks of ownership the sink waste pipe came apart, fortunately I spotted this before the underfloor compartment of the van flooded.
Shower tray has cracked & replaced under warranty.
Hob top enamel has cracked, Thetford refuse to replace it.
