Looking for a pillar drill. Has anyone got one of the offerings from the likes of Warco, machine mart and the like. Needs to run slow 150 rpm ish upwards. Fed up with the limitations of a bench top.
I have an earlier version of this, used it for 4 years - well pleased with it, especially as it's only 50 notes
Performance Power 350W Drill press ODP-350 | DIY at B&Q
This Performance Power corded drill press is best suited for accurate heavy-duty drilling in both hard and soft materials. It boasts 1 function drill functions; with a 5 speed pulley system gearbox providing greater torque versatility. A wide range of drill bits can be easily interchanged with...www.diy.com
Note to self: read posts more carefullyThat's a bench mounted drill that the OP wants to get away from.
I prefer a modern one. had a myford lathe and to be honest the Warco is a much nicer machine to used.Get yourself an old Fobco or Elliot off eBay or Gumtree, even if you have to buy an inverter to run it, it'll still be running when all those newer drills have worn out and flexed themselves to bits !
