Picking up power and reverse trigger A class Fiat (1 Viewer)
Sep 24, 2013
1,318
753
Norwich
Carthago A class
Since 2014
I'm fitting a reversing camera (Camos Jewel 2) and would like some help in knowing where I can pick up an ignition live feed and a reverse trigger for the monitor. Has anyone fitted a reversing camera (twin) onto a A class Fiat based Carthago (mines a C-Tourer). A bit of a long shot but someone may have done it.
Dec 2, 2019
4,127
9,268
South Lincolnshire
Rapido 7065+
Broken most bits now
You could tap into pins 19 & 8 resp on the front of the fuse box under the dashboard
Dec 2, 2019
4,127
9,268
South Lincolnshire
Rapido 7065+
Thanks. Looks like you have a source better than mine (which is none!)
Elearn - widely available for download online. You need a CD or to create a virtual drive to run it on a PC but I managed it so must but very doable for anybody else.
Jan 1, 2014
572
1,336
France
Pilote G691 LCE
Since 1974
What year is the base vehicle if after 2013 most of what you need is controlled by the canbus , before simply tapping into lines check first
Lenny HB
53,703
151,018
On the coast in West Sussex
Hymer B678 DL
Fitted cameras to all my vans, never managed to find the reverse trigger in the fuse box spent ours trying. I find it easier to run run a wire to one or the reversing lights.
For the ignition switched live feed I use the ACC wire to the stereo.
stevec
Sep 24, 2013
1,318
753
Norwich
Carthago A class
Since 2014
The van was wired for a reversing camera as part of the “basic” package. When the guy came to fit the tracker he found the monitor end of the cable along with a switched live connection clipped to it. No reverse trigger though. At a push I’ll use a switch!
Jan 1, 2014
572
1,336
France
Pilote G691 LCE
Since 1974
Usually the units sold to enable the steering wheel controls for aftermarket radios to work on modern vans will have a reverse signal, the Pioneer one does.
Jul 29, 2013
9,076
18,661
Salisbury
Hymer B678DL A class
since 2011
Our reverse trigger cable is at the back of the head unit on the loom from memory green and labelled.
