Peugeot Boxer 3 won't lock. (1 Viewer)
Pikey Pete
1,481
1,143
o
o
I have a 2011 Autocruise Pace on a Peugeot Boxer 3 and I can no longer lock the doors on the remote. It beeps but the locks don't operate.
I think it's something to do with the sliding side door. Does anyone have any experience of this problem and how to fix it?
I have done a search, but as yet to no avail.
All replies and suggestions will be gratefully received.:thumb:
Pete:Cool:
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Possibly "Low Battery" on the remote..
Just guessing... :RollEyes:
Sep 25, 2009
794
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
sonds like one of doors not closed properly.my system does the same. i had a ground sheet caught up in on of the magnetic strips on a locker door.check all doors first including bonnet is shut properly.:thumb:
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
If you get some loose item fall in to the lower door runner , the door will not quite shut properly.
If it won`t close up tight , the contacts on the door edge won`t work ,then none of the locks work.
Also try cleaning the contacts on the door and pillar.
Heyupluv
3,862
1,593
France,
touring many years..42+
Itinerant Pete......I would go with Masman...check all your doors are properly shut.....:thumb:
Mel
Organplayer
110
38
Berkshire
C class
Sept. 1995
organplayer
I have noticed that during the very cold weather, the habitation door will not unlock when using the central locking system "zapper", but will operate with the zapper to lock it. As soon as the frost goes and temp. rises, then it works fine. Just a thought.. Best of luck.
burdenandy
3
6
Autocruise Carrera 4
Since 1980
I have just had the same problem with my 2015 Peugeot Boxer Autocruise conversion, fortunately I have a friend who is a Peugeot Technician and I was advised to:
Disconnect the battery earth lead and touch it directly or by an extension cable to the positive battery terminal for approximately 10 seconds to remove any static present in the cabling and then to reconnect the earth lead to the negative battery terminal.
After doing this both my remote key fobs worked perfectly.
Oct 15, 2012
10,196
57,484
Market Harborough
C Class Laika Ecovip 7R
This thread is 6 years old..............
