C cozzie Free Member May 24, 2021 1 0 Funster No 81,455 MH Hoby 700 May 24, 2021 #1 Battery keeps going flat when parked up, no idea where the current is leaking anyone have any experience/ solution. 2005. Automatic. Thanks Dave.
David and Sally Apr 9, 2018 8,698 45,037 Worcestershire Funster No 53,271 MH Bailey Adamo 75-4t Exp March 2018 May 24, 2021 #2 Radio left on? How long does it go flat after a run? 2005. May be the original or later battery just knackered.
Odd job Jun 29, 2015 3,492 57,720 Southampton Funster No 36,999 MH caravan (for now) Exp on and off since 1984 May 24, 2021 #3 Hi Dave the usual suspects are alarm, a light not going, off faulty battery or alternator, how long does it take to go flat?
Phill D Dec 6, 2011 11,625 25,541 South Wales Funster No 19,136 MH Coach built Adria Exp Since 2007 May 24, 2021 #4 hi welcome. you need to do a simple parasitic drain test. you will need a multi meter and then look up good old utube and there are nloads of videoas showing how.
Geo Trader - Funster Jul 29, 2007 11,757 14,565 Mansfield,Notts Funster No 35 MH Autotrail Tracker FB Exp 45 +years with breaks May 24, 2021 #5 I imagine your battery could be taking a hammering when being towed unless your charging from the MoHo as you run Subscribers do not see these advertisements
dunnah01 Dec 2, 2019 4,120 9,249 South Lincolnshire Funster No 67,140 MH Rapido 7065+ Exp Broken most bits now May 24, 2021 #6 My roadster which I think is pretty much the same car under the skin keeps a charge for weeks so your battery sounds a bit suspect
XxAnthxX Aug 4, 2019 1,923 8,510 North East Riviera Funster No 62,993 MH Low profile Exp Enough to Survive May 24, 2021 #7 Courtesy light in the boot staying on???
Lorryman100 LIFE MEMBER Nov 29, 2015 640 1,015 UK/Scotland Funster No 40,467 MH Rapido A class Exp 27/11/2015 May 24, 2021 #8 How old is the battery? Chances are its gubbed if original.
