- Dec 31, 2010
- 2,646
- 5,851
- Frankia Platin i7900
- Since 2010
This is for DTV, the op is about Satellite.Steve see attached to switch antenna power on
Well I never knew about that I have now switched on and tunned inView attachment 323627
That’s better all the channels without the dish up, top man, Denise can now watch her favourite programs in this galeforce wind.
The aerials were internal I think in the over cab area until about 2016. They then changed to the roof mounted whip and included a DAB amplifier which works superbly.Well the tv has all channels from the Hymer aerial thanks for mentioning that Lenny HB,
I have just had another look on the roof still can’t see anything that looks like one unless it is in the roof ? But working a treat
On that very point Lenny, new B674 and have had interference on fm from the start. DAB fine. The dealer has changed the head unit, pioneer, installed a suppressor type unit that Hymer instructed to install because of interference was a known issue but still an issue. Have a 32in tv and oyster 5. They are now going to change the external arial but I still haven't much confidence that is going to resolve it. Strange thing is when we picked it up no interference for about 10min driving - perfect and then it started. Any ideas?The aerials were internal I think in the over cab area until about 2016. They then changed to the roof mounted whip and included a DAB amplifier which works superbly.
Not surprised you didn't know about it if you bought from a UK dealer. Their product knowledge is almost zero, jumped up car salesman. The German & Belgium dealers know their product.
Never had any problems with ours but don't use FM much I use mainly DAB. TV reception on it is very good although tend to use the sat most of the time.On that very point Lenny, new B674 and have had interference on fm from the start. DAB fine. The dealer has changed the head unit, pioneer, installed a suppressor type unit that Hymer instructed to install because of interference was a known issue but still an issue. Have a 32in tv and oyster 5. They are now going to change the external arial but I still haven't much confidence that is going to resolve it. Strange thing is when we picked it up no interference for about 10min driving - perfect and then it started. Any ideas?
Standard LED DLR in the headlamps I have the new plastic Hymer lampsHave you got any after market DRL fitted this was a source of interference with our Head unit
Probably a stupid question but presumably you only get terrestrial TV on a whip aerial. So if in mainland Europe you get local TV.
Don't forget when abroad if the local station is broadcasting a UK/US program with digital broadcasts you can turn off the dubbing and have the original English soundtrack.Well the tv has all channels from the Hymer aerial thanks for mentioning that Lenny HB,
Didn't bother with satellite. The time you need it and the weather's shi rubbish, you can't use it. And footprint so small abroad now.
