Now works a treat. Thank you Anthony OysterTechRight well that's perfect. There's an option called receiver control that will be turned on so your TV can control the dish but there are different options. Off - This will obviously not control the dish unit at all so you'd use the control panel to manually raise and lower the dish. Auto standby - This will raise the dish when the system detects power coming from the coax connected to the TV and lower it when this power is cut. Auto sleep - This will raise the dish when the system detects power coming from the coax connected to the TV but leave it up when this power is cut.
To access the setting to change this option simply follow the step by step guide below :-
1, Turn on system
2, Press tick to stop system and display "Main menu"
3, Press tick to display "Settings"
4, Press tick to display "Language"
5, Scroll left/right until "Receiver control" is displayed
6, Press tick to display current setting
7, Scroll left/Right to alter the setting as required
8, Press tick to store setting and return to display "Receiver control"
9, Press on/off button until "Main menu" is displayed
10, Press on/off button to retract or tick button to search.
Hope that helps but if you get any problems call the office on 01858575928
