Orange lights on side-length offside + near side. (1 Viewer)
Sep 14, 2022
Swift Kontiki 649
Just obtained a MOT failure because of the 3 orange body lights on either side of my Kontiki 649 were not lit when turning on the dipped headlights.
After lots of investigation and checking of electrical wiring and fuses it turns out that you have to activate the black push button to power up the living part of the motorhome so then these six orang lights come on. Can only presume they are supplied by the leisure battery and not the engine battery.
Hopefully this may assist someone else too avoid expensive labour costs investigating the ‘wiring problem’. No mention of this in the manual guides to look out for.
Jul 29, 2013
9,076
18,661
Salisbury
Hymer B678DL A class
since 2011
Hello and welcome to the forum enjoy the FUN 😊
really useful info I think if I was in your position I would retire so that the came from main lighting loom🤔
Feb 22, 2011
9,857
20,324
Newcastle under Lyme
Hymer B544 A Class
Since 2015
w2f
There is something not right there
The marker lights should come on when you turn on the side lights and be completely independant of the leisure battery and habitation electrics.
I fear you have more investigating to do
Nov 3, 2020
1,293
2,215
Up the Hamble
Ace Siena
Since 2019
Interesting - may be some other fault as the orange lights on mine are independent of any interior switching except the headlight switch.
Mar 23, 2012
9,589
32,245
sleights
c class
It might be worth looking into it does sound really strange I would check on one of the side lights when the hab battery is off to see if there's any power to the positive side I wonder if it's some sort of dodgy earth?
Northernraider
27,505
178,753
On the sofa ....
Mobilvetta eurayacht
On and off since 95
That's no right.
Feb 21, 2016
4,925
29,783
Uk
C class
Since 2017
That’s wonky……technical term used by real experts:ROFLMAO: . Mine come on with sidelights/ headlights,which is how they should be wired.
busbuddy
1,298
2,924
leicestershire
swift suntor 630G
since 1994
Is it its first mot?
Are they factory fit?
Does starting the engine cut off the habitation power turning those lights off?
May 10, 2018
431
694
Bucks
Autocruise Augusta
MH newbie but we owned a caravan previously.
Same on our Autocruise. If you look at the wiring diagram for your Sargent unit you'll find they are indeed wired through the unit hence you have to have it switched on.
Northernraider
27,505
178,753
On the sofa ....
On and off since 95
Well that's a very lazy approach on the converters behalf. The side marker lights come with the chassis and should be wired to the vehicle electrics not the habitation box.
May 7, 2016
7,295
11,794
West Sussex
Carthago Compactline
Since 2003
Ridiculous arrangement, could easily be forgotten when driving off. Perhaps they think you should have the ability to turn them on when parked on a road at night but this could be easily arranged using a changeover relay without compromising the driving use of them.
Oct 24, 2020
572
2,387
VW
Since 2017
As has been said, should switch on with the obligatory lamps.
jollyrodger
6,282
26,426
Devon/Cornwall
'Obby
Since 1968'ish
As has already been said
Someone at some stage has been bodging and not found the real problem.
Side and top markers on with sidelights.
Or as you have found out
An mot fail.
Good luck.
And
Sep 17, 2017
5,523
10,325
Birmingham, UK
A-Class
I thought wisdom was that the hab side electrics should be off while the engine is on?
Ours has an annoying feature. The bed is over the cab. There are no cab lights when you open the cab door. There are overhead lights on the underside of the bed that are touch activated, but the power is from the hab electrics. So no good when you climb into the van after dark.
Northernraider
27,505
178,753
On the sofa ....
On and off since 95
Mine too has lights under the drop down bed fed from the hab battery but they come on when you open the front doors or activated by a switch on the dashboard. The stereo also works with ignition but can be switched on from the rear lounge or the front dinette also.
I think it's just the difference between European vans and British builds.
Sep 17, 2017
5,523
10,325
Birmingham, UK
A-Class
It's got a €0.10 switch drilled though a random bit of dash panelling near the gearstick for the radio power toggle. Nothing useful for the lights though.
Northernraider
27,505
178,753
On the sofa ....
On and off since 95
and the side marker lights are obligatory as seen by the MOT failure.
Actually I'm not sure if that's entirely correct. I think if they are there they have to work but if not there they aren't a fail.
Because the merc vario I have at the minute doesn't have any and it should but its passed the last few mot tests and no mention of them.
That said I've not had it tested myself yet so might have been a tame mot tester
I plan to refitt them anyway
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
By orange marker lights, I’m presuming that you mean the external side marker lights on the bodywork?
If so, these should be wired to your side lights and to your engine battery.
They should be independent to your internal lights or leisure battery.
If one is not lit, it is an MOT failure.
My first port of call would be to take the lens off and clean out the terminals and the bulb holders and spray some wd40. I once had a side of lights out and it was due to a faulty connection which was rectified by giving it a good clean.
Next would be to trace the wiring as they need to be connected to your side lights and not any after market switch.
Oct 10, 2018
2,016
1,142
Bracklesham Bay, West Sussex
PVC
Richard Pearson Your marker lights will still be powered from the starter battery but if you have the PSU shutdown button off the relay that allows the marker lights to operate at the same time as the other lights with the engine running/ignition on cannot work (your fridge will also not work on any setting with the shutdown button off). The shutdown button is normally only used when in storage to avoid the PSU having a slight drain on the leisure battery over a long period.
Gellyneck
9,275
18,432
Scotland
More than toes wet now!
That said I've not had it tested myself yet so might have been a tame mot tester View attachment 664609
Legislation here -
Think your Vario may have to have them fitted but ................?
