Noisy water pump (1 Viewer)
sootie
4
Donegal Ireland
low profile
09 Reg
Just purchased a chausson welcome 76 (09 model) i find the fresh water pump very noisy is this normal for this model .
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
Shouldn't think so.
I know this is a bit like the TV troubleshooter (No picture - Make sure TV is plugged in and switched on.:Doh:) but maybe there's a bit of an airlock in the pump. Or perhaps it's not bedded on anti-vibrations mounts, or maybe (unlikely, but you never know) the impeller bearing is shot.
Just a few (admittedly not very high tech) thoughts.
John
kennygd
197
9
Anywhere in the UK
Starting out fulltiming
:Smile:Mine is a bit loud on my Autotrail but not knowing what it should sound like I can't compare, I just take it as normal.:thumb:
brodie
413
131
South Yorkshire
Van Conversion
since 2008
We have a Chausson and the water pump makes a right racket. Sounds like a numatic drill :Eeek:. Hubby has re-mounted and insulated around it and this seems to muffle it quite alot.
Oct 14, 2007
4,030
6,344
Rochester
Auto-Trail Mohawk
17 fun filled years
If it hasn't already got one fit an accumalator, it helps with the pulsing and knocking :thumb:
Look at this thread I started
Link Removed
S
sootie
4
Donegal Ireland
low profile
09 Reg
Thanks for the replyies on the noisy water pump in our chausson welcome 76 does anyone know were to locate the pump?
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi Sootie
We have the same model as you, the pump is a bit noisy but not as noisy as the bessie we had before. I know that wont answer your question but ours isn,t to bad at all , as previose replys check its not loose etc. Pete :thumb:
ps lovely vans though.:thumb::thumb::thumb:
S
sootie
4
Donegal Ireland
low profile
09 Reg
Found the pump located forward of the fresh water tank, as it is situated out side the tank it has to be nosier than the pumps fitted in our previous motorhomes which were submerged in the fresh water tanks ( Hymer & Burstners )
